-   -   Heat Alarm wire.. (https://www.offshoreonly.com/forums/general-q/313431-heat-alarm-wire.html)
stlliberator 06-07-2014 03:12 PM
Heat Alarm wire..
So I figured out that my boat the heat alarm isn't hooked up..and I found that out after looking down at my temp gauge hitting 230 degrees...I have a thunder bolt ignition...does anyone know the heat alarm wire color to hook up??
Griff 06-07-2014 09:47 PM
I assume you mean the high water temp alarm????
There is a Merc alarm sender that installs in the intake. Then the tan wire with blue stripe connects to the sender.
