-   -   Rooster tail fittings on Normal drives - What and where? (https://www.offshoreonly.com/forums/general-q/313825-rooster-tail-fittings-normal-drives-what-where.html)
phragle 06-16-2014 04:47 PM
Simply mount 27 transom pickups on the back of the boat with the outlets pointing straight up.
jrstoybox 06-16-2014 04:57 PM
Originally Posted by 4bus (Post 4138478)
Oh boy....those ARE surface drives, Indy to be exact. And like the others told you, the "pipe" is to get the HUGE diameter surface piercing props moving when they are fully submerged off plane. Once on plane the "pipes" (as you refer to them) are above the water line and no longer aerate the prop.
I am sure there are all kinds of things you can bolt on to your boat that will throw water in the air, slow you down, cause drag, and make your boat handle dangerously, just to look like a surface drive boat in the eyes of those that do not know any better.
You're right after I looked closer at the video it's clear as day. I definitely don't need them on my 303 but was considering it for my next which will be a 353 or 382.
Elite Marine 06-16-2014 05:02 PM
Cops around Chain crack down on rooster tails. Also its really a pain for anyone trying to run with you.
RT930turbo 06-16-2014 10:31 PM
What Year is your 303? We moved up from a 303 to the 382 last season. Loved my 303 :drink:
FIXX 06-17-2014 12:18 AM
Originally Posted by mickeymcclgn (Post 4138151)
Those are prop airaters (sp?) that looks like it could be a NXT or a #6 drive setup and it needs to airate the props to get some slip and get the motors revving and get on plane. You see them on a lot of the race boats and fast sh*t. Nothing that I own lol.
neither ,ilmor,indy drives..http://www.ilmor.com/en/marine/perfo...ern-drive.aspx
VoodooRob 06-17-2014 07:41 AM
Those are fishing rod holders, everyone knows a Formula is an old man's boat and can't go fast.
jamontes 06-17-2014 07:51 AM
This thread reminds me of the posts on the diesel fourms titled "How do I make my truck roll coal" or "Where can I purchase a smoke switch?"
