-   -   Mercruiser Head Gasket Sealing (https://www.offshoreonly.com/forums/general-q/313850-mercruiser-head-gasket-sealing.html)
CIG3 06-16-2014 12:07 PM
I'm putting a 228 Merc together for a friend. He dropped off everything including the gasket set. The head gaskets are coat stamped steel. What if anything should I use on them to seal things up? I figured just a little hy-tac or something around the water jackets.....
ezstriper 06-18-2014 08:25 AM
I would not use steel gaskets in a marine engine, use felpro...the steel will rust away with out fresh water cooling which I'm betting this does not have...
mike tkach 06-18-2014 09:32 AM
i agree,fel pro marine head gasket is the way to go.
