FAST Programmable EFI
3 Attachment(s)
The last few weeks I have been playing around at the shop with the new FAST EZ EFI 2.0. I don't believe it can get any easier then this. It comes with a little tablet and you just need to answer a few questions.
This is a direct carb replacement. Everything comes with it, fuel pump, regulator, gauge, filter hoses and hardware. This is the 1200HP kit that has 8 injectors in it and will flow ~1050cfm. JimV (Valako) just installed a pair on a set of 540's he just built. I think I might be going to EFI soon. [ATTACH=CONFIG]524833[/ATTACH] [ATTACH=CONFIG]524834[/ATTACH] [ATTACH=CONFIG]524840[/ATTACH] https://www.youtube.com/watch?v=njqqYyLhYJE&app=desktop |
I've heard of guys using the FAST EFI on drag cars around here, never thought about a boat application. Sounds nice!!
I think they require 02's and there may be the issue..
Originally Posted by ezstriper
(Post 4139448)
The cams are relatively mild making around 700HP. |
Keep the 02s dry and they will work for a long time.
Originally Posted by GPM
(Post 4139740)
It looks like a pretty nice setup. I have read other post about programming it and it seems like you give it some parameters and it self tunes. I can't really tell where the injectors are with your pictures. Are they in each intake runner or?
Originally Posted by 28Eliminator
(Post 4140153)
Is this a returnless fuel system? It looks like I see two inlets unless one is the feed and one is the return.
(Post 4140153)
http://www.youtube.com/watch?v=MXiX3EBT9dE
Originally Posted by donzi matt
(Post 4140203)
(Post 4140112)
that is easier said than done with some exhaust...
So where are the o2 sensors?
In the headers, kept them a little closer to the block,
1 Attachment(s)
Originally Posted by Pismo10
(Post 4140500)
[ATTACH=CONFIG]524925[/ATTACH] |
This looks really cool!! Do you you only run one 02 sensor in each motor? Looks like the other tail does not have a sensor in it. Also for us roots style blower guys, could you get away with only one throttle body on top of a 10-71? Right now I run twin 850 Holley's on top of my 10-71's but if each throttle body will support 1200hp that would be plenty. I too would love to go EFI!!
you only need one to get tune in, just some exhaust keeps getting the wet and kills them quick, lightnings for sure, plenty of talk about that on here...
I just called Fast and they said this quick learn system does not work with any power adders, but there XFI system will. However the XFI system will still require tuning and programming, not a self tuning system...
i have been looking into this for months and i am dead set on doing this EFI setup. i have a older holley MPI kit that i have everything to make it run but i don't want to deal with programming the old school commander 950 computer. i have not found allot of feedback on them but i have found actual marine engine companies selling their brand new warnateed engines with them so they have to be working well. the bad comments i have seen are from people that have tried putting them on engines that are beyond a basic self tune setup. i am planning a 496 stroker with aluminum edelbrock heads, hoping for 550-600hp. i am running gil HP500 style tall manifolds and risers so i don't believe that i will have too much of a issue with keeping the O2s dry. good post!
I contacted Fast awhile back about their self learning systems and the thing that killed my application is that they need to see 9" of vacuum in gear to tune properly. My cam is too big I barely pull 9 in neutral. FWIW
Originally Posted by ThisIsLivin
(Post 4146580)
from what I understand, many have a self tune deal now, which work for milder engine setups, boosted, and more radical ones will require some tuning on your own...but that's not that bad one unit is close...
Originally Posted by Budman II
(Post 4146611)
What is your initial timing set at? It is my understanding that going to a module that allows you to run more initial timing may help it to idle better in gear and it may boost your vacuum signal. A lot of guys with big cams and blowers, etc., have gone to the V6 module, which allows you to run 20*+ at idle.
What was the total cost per motor for this swap, Rookie?
Originally Posted by Cole2534
(Post 4198912)
Ouch!
So that, plus heads and intake would turn a mild MPI 509 into a pretty smooth operator for not a lot of coin.
(Post 41285)
Originally Posted by ICDEDPPL
(Post 4199277)
Ouch!
FAST told me they do t reccomend their system for a marine application. Any issues other than mounting the O2?
Originally Posted by murfman
(Post 4199325)
Rookie is there a way I can get a hold of you. I have some info to pass on to you. That's it, nothing pressing or bad.
Yes, I tried to PM you, but your in box is full.
Jason |
Sorry been out all day today. if you would like to hit my email up. I leave my PM full up here, I have my reasons.
In the email post something that I know to open it up. I do not open up emails that I have no clue who they are from. [email protected] if you could leave a phone # and a good time to call. I bet you are wondering what in the hell and why I would be calling you. Its all good. |
All good
Email sent, it's from my Yahoo account. Jason |
Sent a reply email back to you with a link to read and to look at. Let me know you got it. THX
| All times are GMT -5. The time now is 07:50 PM. |
