-   -   Gen 4, 5 and 6 GM heads same plug reach? (https://www.offshoreonly.com/forums/general-q/314179-gen-4-5-6-gm-heads-same-plug-reach.html)
Wobble 06-23-2014 11:48 AM
I am running Gen 4 GM rect port heads, need to get some plugs for a boat equipped with Gen 6 or 5, sight unseen. Think they all have the same reach but not certain. Thanks
Wobble 06-28-2014 07:22 PM
Ok I researched this and found that they all take .460 reach, standard or extended tip plugs
ngk R5673-7,8,9 or Ngk R5674-7,8,9
Young Performance 06-28-2014 08:59 PM
If it's a stock engine. the 7's will be to cold. In stock engine's, use an NGK R5673-6 or BR6FS.
Eddie
Wobble 06-29-2014 09:26 AM
Thanks Eddie, 9.8-1 runs up to 5600 fairly similar to mine except for the Gen. His is 560hp. EGT's were high on his (due to crappy marine carb I think) so I was thinking 7's with out the extended tip would be a safe bet
ezstriper 06-29-2014 05:30 PM
the rect ports do, but the oval ports do NOT take the same reach plugs
Wobble 06-30-2014 10:55 AM
Good to know, thanks.
