Carb help
I'm having trouble keeping my engines running in gear . It is idiling at 1000 rpm out of gear and drops to 550 in gear. They are 540ci 600 hp 950 quick fuel carbs. 35 total timing with black bushing in dist for more initial timing. Makes 5 inches of vacumn at idle. I don't have experience tuning using the air bleed jets. I would like it to have another 100 rpm or so in gear for a stronger idle. It smells fat at idle but if I turn the idle screws in any more it doesn't idle at all in gear. The engines were dynoed and perform flawlessly everywhere else. Just looking for any suggestions on the weak idle in Gear. I have also drilled a .040 hole in each throttle blade that did help.
What is your initial ? I Haven't done MSD dist's in eons.
Did you adjust your sec opening ? If not, should have done this before you drilled the holes in blades. Between timing adjustments and secondary idle air flow, many times (not all of course) you can tame down the idle. |
I wouldnt have drilled the throttle blades.
Are you sure the primary throttle blades are set properly as far as their location in reference to the transfer slots? How about the secondary throttle blades? You do not want to see the transfer slots on the secondary side. Sometimes if the engine is too lean at idle, and misfiring, the exhaust can smell rich too. 5" of vacuum at idle is pretty low. What kind of cam is in that thing? Are you sure you dont have a vacuum leak? Its sounding like you'd need to either go a little smaller on the air bleed, or larger on the IFR to richen the circuit up. In nuetral lean can mean high idle. but in gear running out of gas will make it want to fall on its face. how far out are the mixture screws when it wont stall out when in gear? |
I agree it sounds like a vacuum leak. 5in is way low assuming that is out of gear. Even in gear that is nfg. Spray some starting fluid around the base of carb and intake to see if rpm changes. Make sure no stray sparks are present, but you know that already.
With the MSD Black bushing you will have 17 degree advance at idle, the Black bushing gives another 18 degree advance, I use the Black Bushings on mine with 540's and Holley 800 cfm #9022 carbs, idles perfect at 850 rpm in neutral, 650 rpm in gear w/28 pitch, how is it jetted in front., also not sure you need a 950 carb.
Jets are 78 front and 86 rear. Idle bleed 73 primary bleed 32
When it is up to operating temp. and out of gear put your finger over one of the idle air bleeds. If it pick's up RPM it's most likely to be lean on the Idle air bleeds. If it looses RPM its most likely rich. The IAB's are the ones to the outside.
Originally Posted by flat rate
(Post 4149641)
I have a quick question on your Quick Fuel's. Would they by any chance have a provision for and be calibrated for a PCV valve ?
Was it running OK and just started doing this? A 540 with 600 hp should have a pretty mild cam and hold a little more manifold vacuum .
| All times are GMT -5. The time now is 10:01 AM. |
