-   -   Screws for exhaust tips? (https://www.offshoreonly.com/forums/general-q/314940-screws-exhaust-tips.html)
jbraun2828 07-09-2014 09:55 AM
Hey guys, I just ordered some new tips and they don't come with any screws. Does anyone know what size to use, how thick and how long? Thanks in advance
stlliberator 07-09-2014 10:55 AM
Depends on the thickness of your transom...just buy the same ones that your taking off of the boat now.
jbraun2828 07-09-2014 11:00 AM
Don't have any now, have mufflers that are thru bolted.
F-2 Speedy 07-09-2014 12:00 PM
I would wait till you get them, they should have bevelled holes in them, buy the ones that the head of the screw best fits the hole, stainless 1 to 1 1/4 inch should be fine, and seal them well
CC230 07-09-2014 01:16 PM
Can you through bolt the tips? If the holes line up?
dereknkathy 07-09-2014 10:30 PM
if holes line up you should definitely thru bolt them. you can get 1/4 20tainless with the beveled Phillips head. since holes are probly 5/15ths for the 1/4 bolts to go thru, they will be a lil big for any Phillips head wood screw. of course you can always paint a dowel with poly resin and shove it into hole and redrill.
