-   -   Bad powersteering pump? (https://www.offshoreonly.com/forums/general-q/315077-bad-powersteering-pump.html)
502 Magnum 07-12-2014 06:13 AM
My boat has strong torque twist to one side at speed,I need to realy grab the wheel hard,500EFI with Bravo X 1,36-1 and B1-24`prop .No play in gimbal.
It looks to me it`s no backup from the powersteering,is it possible for the powersteering actuator or the powersteering pump to go wrong?
ezstriper 07-14-2014 02:38 PM
at idle how does it turn ? pump does not know left or right, if you are having a difference from left to right look at the actuator, that controls left to right pressures
502 Magnum 07-14-2014 05:00 PM
It feels like very litle help from the powerstering,only the helm pump doing the job.Thanks
ezstriper 07-15-2014 08:30 AM
the helm is no pump, it just directs fluid flow, either pump gone of filter clogged, sounds like pump done...
502 Magnum 07-15-2014 04:41 PM
Yes I have a separate helmpump instead of the std cable steering.
