electric circulating pump??
Anyone ever run an electric circulating water pump?? Curious as I have closed cooling and need a circ. pump, but would like to free up a few hp from the drag on the belt system?
Just ordered a replacement Mercruiser circ. pump but for about $50 more I could get an electric pump. Thanks, Chris |
Originally Posted by cdaniel525
(Post 4160212)
Just ordered a replacement Mercruiser circ. pump but for about $50 more I could get an electric pump. Thanks, Chris If you are drag racing and only run the eng for short periods, you can run off the batt only and free up some hp. |
Interesting... I didnt know there was additional drag on an alternator when it is charging the system even more!?
Don't sweat the thought. You won't feel the difference..ie: it won't move the Speedo any further.
Alternators may use just a few hp from drag and a few hp if charging a decent load......water pump (recirculating) under 10hp at high rpm. Drag car fighting with rules and for every hp, different story. But still very small change. Look up Alternator draw on the net, you'll find electrical loads vs hp used to make it. I've dyno'd many different engines including one marine engine fully rigged with bravo raw water pump and water going thru complete exhaust. Result....again...don't sweat it. My IMHO with what I've seen, Stay with reliability and ease of rigging, again, since hp difference is so minimal. |
Thanks for the info.... main reason i was thinking about it was the small amt of hp AND the consistent flow not depending on RPM...
I already ordered a Merc Circ pump anyway... And after the shipping costs I dont think itd be worth shipping it back and lose shipping costs both ways Just for arguments sake, whats everyone thoughts on the consistent flow subject? |
also a drag car is only really creating engine heat for 6 to 15 seconds. rest of time at essentially idle where a small elec pump can cool it. we are at 1/2 throttle or more all the time. the only other engines with this kind of duty cycle are airplanes and big trucks. even your f350 towing your boat down the highway isn't running that hard...till you go up a hill.
Makes sense dereknkathy.... Wonder what the flow rate of a Merc Circ. pump is vs. the 35gpm Proform electric pump i was looking at.... Im sure at idle when the voltage drops, the pump doesnt flow that full 35gpm either
(Post 4160505)
Originally Posted by dereknkathy
(Post 4160517)
the "the coolant is flowing thru motor too fast to absorb heat from the engine" theory is plain wrong.
Figured that same fast consistent flow from aelec pump at idle would be a good thing... but it has other drawbacks pointed out above |
(Post 4160512)
| All times are GMT -5. The time now is 07:48 PM. |
