Intake ?
Can you go from a rectangle port head to a Weiand blower oval port intake manifold? If you can what is the best intake gasket to use?
I think its possible, ive heard of it done but have never done it myself.
I would think you need to use the oval port intake gasket. But I could be wrong |
Originally Posted by Craney
(Post 4169263)
Can you go from a rectangle port head to a Weiand oval port intake manifold? If you can what is the best intake gasket to use?
Very hard to do because most oval port intakes will not cover the top of the rectangular port openings in the head. Can you say massive vacuum leak ?
However, the Dart Single Plane Oval Port intake usually has enough height to it's head mating surface to cover the rectangular port openings on head. And yes, many have done this. |
I would think you would want to use the square port gasket, provided there is enough surface to fully seal it as SB has mentioned.
I think one of the older Holley High Rise Dual Plane (oval port) Intakes would seal it too, but that was a long time ago, and i'm old, so that millimeter of a memory may be way wrong. Howevever, I have good memory on the Dart Single Plane Oval Port intake.
This is NOT my motor it's a friends motor. This is a Weiand blower intake.
See how things mate up and go for it.
Since you deflated my sails by not giving us correct info earlier.
I'll ask now: which Weiand Blower ? They made several different sizes. Ah, forget it. Just call Weiand. If they have no answer - they should - then do what was said above and take the intake and lay across a rect port intake gasket and see if it will seal. |
I think it's 177 but I'm not sure this is not my motor.
