-   -   Lower than I like Oil Pressure (https://www.offshoreonly.com/forums/general-q/316800-lower-than-i-like-oil-pressure.html)
the deep 08-15-2014 10:33 AM
Originally Posted by mike tkach (Post 4172121)
what was the origional hp of your engines?just say TACK.like tackometer.
Or tic-tack . :party-smiley-004: :whistle:
endeavor1 08-17-2014 03:54 PM
What's the size of the oil cooler you have on now? I'll check it against what's on my former 500s
payuppsucker 08-18-2014 10:23 AM
Stock replacements for the 502 mag from Mr. Cool. I think they are 4x18 Chris.
endeavor1 08-18-2014 12:03 PM
I ll look at mine when I get home tonight from STL. I'll call ya Kelly
payuppsucker 08-18-2014 04:22 PM
Sounds good
MILD THUNDER 08-18-2014 05:10 PM
Ive seen plenty of electric oil pressure gauges read far off from whats really going on. For example last year, my port oil pressure gauge was showing down around 25psi at idle in gear after a hard run, while the starboard showed like 40. I put a mechanical on the port engine, was actually about 45psi hot idle in gear. My chevy oil pumps have been shimmed. I see about 75-80psi warmed up and running at 4000RPM. Cold, getting on plane, gauges are nearly 100psi. On the dyno my engines had 100psi with no coolers, lines, remote filter, etc. Just had the filter on the block like a car would.
Also, I have all 1/2NPT fittings and #12 lines to and from my coolers/filter.
payuppsucker 08-18-2014 10:01 PM
On my dyno runs both motors were low seventies but just like you describe, oil filters on block adapters. The low op started as soon as I installed the motors in the boat with coolers, lines, adapters. Also, my cold start idles pressures are high 60s and temps are 200ish with an infrared gun at the filter. I'm going to get my new gauges installed with new senders, install my temp gauges, change all my lines to -10 or -12 pushloc with high flow fittings and see what I have after that. If it's still not where it needs to be I guess it'll be new coolers, filter housings, block adapters. My pumps are high volume but standard pressure.
payuppsucker 08-18-2014 10:04 PM
Is my pressure low because of the restriction alone or is the restriction causing my pump to bypass within it's regulator, (spring)? They're Gen IV blocks.
ezstriper 08-19-2014 06:43 AM
If you take a close look at the fittings on the filter adapter, block adapter, cooler you will see how bad they are flow wise, just doing some is like pissing in the wind..
