-   -   oil temp (https://www.offshoreonly.com/forums/general-q/316996-oil-temp.html)
preferred1 08-19-2014 09:13 AM
oil temp
Overnight my oil temp is going up to 200 deg. when idling. Checked oil cooler,seemed fine.Oil pressure is fine , water temp is good its just oil temp. Guage is fine . Any thoughts ?
skydog 08-19-2014 11:11 AM
Sounds great to me?
ealesh33 08-19-2014 11:17 AM
Are you getting pan temps? basically is your sender before or after the cooler? 200 is perfectly fine if you are before the cooler, if it is after the cooler I would say its just a touch high, but not really concerning. More of a concern is the change, so the question is why did it rise in temp from what it normally is.
