-   -   Anybody use these boat dollies? (https://www.offshoreonly.com/forums/general-q/317208-anybody-use-these-boat-dollies.html)
502ss 08-24-2014 05:10 PM
Looking to buy a couple of these (specifically the 3600 v-boat). Anyone used them before?
Good, bad?
Any pictures of your boat on them? curious how low you can get the boat to the ground.
http://www.crcmarinesupply.com/Boat%20Dolly.htm
Thanks in advance
Jim
Jolt 08-25-2014 02:19 AM
We use what looks like those exact v dollies at work (except ours are black). You can get the v of the boat a fraction of an inch above that frame, so just a few inches off the ground. It is definitely a multiple person job to lift a boat onto them though. We usually use 2 forklift operators (one in the front and one in the back) and a guy aligning the dollies as we drop it down slowly. That connect-a-dolly thing seems like a good idea and might make it a little bit easier, especially when you get it all set up and adjusted the way you want for your boat. Always make sure you have 2 people when rolling the boat around on these as well. They wheels roll almost two well, and with all casters it can be a little challenging to get the boat moving in the direction you want. If you have a shop where space is tight and it would be easier to do that than hook up a truck and move it around then go for it. Great for working on trailers as well, but moving the boat around with a truck is definitely more convenient if it is an option.
502ss 08-25-2014 06:39 PM
Thanks for the feedback! You make some great points. The reason for removing it from the trailer is so I can get the back half of the boat in my garage. With the boat on the trailer it is about 8" too tall!
Anybody else use these?
Jim
Jolt 08-25-2014 07:19 PM
I'd say the lowest you can get the hull is probably 4-6" off the ground. I'll see if I get more accurate numbers when I go in tomorrow, but unless your hull sits fairly high on your trailer, I don't know that you will gain quite enough using these dollies.
murfman 08-25-2014 07:24 PM
I made my own, height was not an issue for my but even still its 3" lower than the bunk trailer I brought the boat home with.
http://i184.photobucket.com/albums/x...ps3e7d07e5.jpg
http://i184.photobucket.com/albums/x...ps08b4025e.jpg
502ss 08-25-2014 07:28 PM
I also thought of building my own but it's going to be near impossible to build them for $280 a piece, yes I could build them but these have all the adjustments, powdercoated, carpeted bunks, high end wheels, etc. again tough to build for that price nevermind the labor, time is money! :)
Yours like nice though!
Unlimited jd 08-25-2014 07:44 PM
I don't know about you but my boat sits a lot higher than 6" off the ground on the trailer. I'd think at 4-6" and Jim only needing to gain 8" they should work well. Jim just make sure your skegs will be high enough if you get the hull that low. Although it's not the end of the world pulling the drives to store for the winter.
donzi matt 08-25-2014 07:56 PM
Jim
Jim I have a set of dollies in my shop that I had thrown in on an engine deal from a few years ago similar to these. They are just sitting up in storage so if you would like to borrow them this winter and see if they work for you feel free, I won't be using them this year.
murfman 08-25-2014 08:25 PM
I paid 200$ for all 8 wheels shipped, and had the C channel laying around from old projects, that said even buying the steel It would have cost me 500$ and two afternoons in the garage. Northern Tool and Harbor freight both have many caster wheels to choose from.
kevinb230 08-26-2014 01:37 AM
if you're trying to get it lower, would it be better to put the casters on your trailer then take the wheels and/or axels off of the trailer. It would be way more stable and maybe as low.
