-   -   adding 174 blower (https://www.offshoreonly.com/forums/general-q/317236-adding-174-blower.html)
hullofjustis 08-26-2014 12:10 PM
[QUOTE=bigbird241;4178095]
Originally Posted by hullofjustis (Post 4177957)
my X is pretty high now, prop shaft is about 6 inches under center of boat. motor is built with forged pistons, h beam rods, steel crank. Im only looking for 3-5 psi boost, i dont want to invest in a new drive right now.
i would think by the time you are finished buying a blower, carb etc. you would be more than a imco lower unit?
i have my drives level with the hull on a set of ext. boxes on my scarab panther
bigbird241 08-26-2014 05:55 PM
Friend of mine has a -2, I might try it for ****s and giggles
dsmawd350 08-26-2014 06:25 PM
Buy the 250 blower setup that just got posted in swap shop
hullofjustis 08-27-2014 06:55 AM
Originally Posted by bigbird241 (Post 4178359)
friend of mine has a -2, i might try it for ****s and giggles
i highly recommend it
bigbird241 08-28-2014 07:00 AM
If I went with the bigger blower, then It wouldnt fit under my sun pad. otherwise I would definitely go that route, Im only looking for 3-4 psi.
Unlimited jd 08-28-2014 07:16 AM
Pressure is not what you want. Volume, and cool efficient volume at that. Gould set that 250 up to make 3lbs, and make more power than the 174 @6
