Bilge pump in Fountain left running dry- are they toast?
The bilge pump switch on the dash was accidently flipped last night while putting on the cockpit cover and I discovered it running the next morning (about 12 hrs+). There was no water in the bilge and it ran dry the entire time. Is it ruined like a seawater impeller or are they designed to run dry? I will be pulling the boat out of the water in a few days and will run water into the bilge to see if they all (I have 3 pumps) work but would like to know if I should be looking at ordering replacements now.
It should be fine. They are not a rubber contact impeller like a sea pump impeller. They are more like a screw drive that conveys water. They test run them dry for hours in quality checks. At least the attwood ones are.
The pumps are in a 2005 Fountain so I assume relatively modern and surprisingly sounded normal when I caught it the next day. In any event I'll test them in a few days but I'm feeling some relief with your comments. thx
I test mine at the beginning of each season, and at some point midway throughout the season. I was quite surprised that the bilge pumps are so quiet when operating.
Why wouldn't it be a good idea to have an alarm on the pump - that way you know if/when its running? I guess on some boats it would be going off all the time, but....
Not exactly on topic, but I have always hated where they mounted the pump on my boat. They have it mounted way up under the front of the engine. When it runs, it still leaves several inches of water in the bilge under the oil pan. Only thing I can figure is they were worried about clearance with the oil sump.
