Opening a can of worms
Hi All,
I am new here and a relative new boater in general. I boated for years when younger and apparently looking for my youth again has brought me to the high performance boating world. ( living on the water I'm sure helps) Ok here is the million dollar question. I am on a budget so with that in mind and my mechanical ability I am looking at three different boats. One a 1976 Chris Craft 8 meter (27) XK8. (twin 350 Volvo PT*80) 1985 Baja 26 454 Bravo 1 Formula Liberator 26 Twin 350 Volvo PT80 Trying to determine which of these boats to choose. al require interior redo (cushions wood work etc.) With out too many details any thoughts? Thanks Jeff |
1985 baja bravo one? is that correct ? bravio's did not come out untill 88 i think. i think bravo parts would be much easier to come by
All are old and will probably make you regret getting into boating. Unless you have excellent mechanical skills, unlimited time, and deep pockets.
Out of all 3 of those old boats, one things for sure, I'd be checking the entire hull structures for rotted stringers, transom, coring, etc. and making sure fuel tanks arent leaking. got to be careful with these older boats. Nothing worse than buying a boat, sinking tons and tons of money into them, plus hundreds of man hours, and never get it back when it comes time to sell.
There are some good older boats out there for cheap money. I'd buy one that has been cared for, and has mercruiser engines/drives, so you can find parts if needed. Technology wasnt that great in the 70's, lot of those boats became rot infested. |
Budget??
Definitely stay away from anything with those old Volvo drives.
What's your price range? I am sure if you do some looking you can find something late 80's with mercruiser running gear in decent shape fairly cheap. |
My .02: For a newcomer??
No Volvo or OMC drives. Nothing over 15 -20 years old unless EXTREMELY well cared for. Go with the common everyday names, Fountain, Cigarette, Baja, Active Thunder, Donzi, Formula, and many good others will be named in this discussion. Call trusted dealers like Pier 57 and talk to some of their sales guys and they'll give you some great ideas. And stay away from salt water boats unless you are an "old salt" yourself. |
I know it may sound like doom and gloom rather quickly ,but these guys are gonna tell you the truth without sugar coating anything. I've only been following OSO for a short time ,but the advice they give is usually spot on. Most of us have been in the boating industry for a long time and I ,myself have bought my share of turds throughout the years. The members here are just going to try to help you not make the mistakes we or others have in the past! That being said , Single engine Mercruiser package is a good start(most shops have parts and knowledge to work on them). GET BOAT SURVEYED or hire a REAL BOAT MECH to check it out , otherwise you may double or triple your budget (bad stringers ,transom, motor, ect.) Also keep in mind,there are a lot of boats for sale that owners have poured a ton of money and sweat into that can be bought for a great price compared to what you may end up spending on a fixer upper. Good Luck and Happy Hunting!!!
Give us your budget and intended purposes and we can help you out better that way.
My apologies. the Baja is an 87 and an OMC outdrive. force 250
Originally Posted by Jeff Parkin
(Post 4185544)
If you can afford to skip the Force models from Baja. They will be almost impossible to resell. I would also skip the omc drives as parts are becoming limited.
Well then. I may take up downhill skiing.
Kidding aside thanks for the help. Thanks for the information on what to look for. I am looking to spend approximately 8 to 10K (Canadian) (I think that translates to about 500 US?) I am going to continue to look into some other boats in the area as pricing drops once the cold breeze off the lake sets in. I will ask more if I have one in particular I am thinking of. Thanks again guys. If any one knows of a good used Canuck version feel free to send my way. Thanks all appreciate it. |
Stringers were replaced in 2010. not sure who did them though. they do however LOOK ok.
Thanks atitude |
I know it's not any of the boats on your list but I know of a 24 Pantera that can be had for around $10,000.
Last I checked Canadian $$ was worth a little more than US. Not much but a little more.
So, at $8-$10,000 you should be able to find something alotbetter than the choices you had previously mentioned. |
Absolutely nothing wrong with Volvo outdrives. They are similar to Bravos and work and hold up well behind small block power. Parts are easy to come by and replacement drives can be found pretty cheaply, I have recently bought 2 SP-A drives complete from bell housing to prop for a total of 1500$. In your price range, I'd look for an old Nova or Magnum 27 hull. Just be prepared to replace the transom on any old resin bucket, after 30 some years, water has most likely found its way in,
Originally Posted by Baja226sport
(Post 4185550)
I guess it comes down to how you do your boating. If you run mainly smaller lakes and rivers, the Force 235/265 is a great option, especially if you ever overnight on it. I guess if you run a lot on big water and don't overnight, and cockpit room is not a big consideration, best to look at a deep-V hull in a 24/7 type hull. Not trying to sound like I'm poking at you - just curious about your thoughts behind that statement. :drink: |
Because the force models are cosmetically unappealing. They look like they are older than they actually are and last I checked the looks of a boat are the first thing to spark interest when selling.
So, I guess if you are buying and are just looking for a cheap boat then the force models may be the way to go. But I have never seen one that had much appeal even if someone tried to update it. |
Sorry Budman, I was just saying they seem to go up for sale around here and sit on the market forever unless the owner wants to give them away.
There is a 235 near me that is very clean. Big block/bravo boat. On trailer and trailer clean. Been for sale 2 years and is currently priced at $9000. |
(Post 4185974)
So, I guess if you are buying and are just looking for a cheap boat then the force models may be the way to go. But I have never seen one that had much appeal even if someone tried to update it. I'll also agree that a LOT of the older boats' resale value is being hurt by the glut of newer model boats that are hitting the used market with the economic downturn. That's why you see so many of them being parted out. |
| All times are GMT -5. The time now is 07:11 PM. |
