Bbc valve cover question-hardin extreme
Can anybody tell me if you can remove bbc/454 hardin marine extreme valve covers with stainless marine exhaust installed.
Or is my only solution to go with 2 piece covers. Thank you in advance. |
if their the angled one's , you should be ok, but I would ask Hardin
I have socket head fasteners on the angled valve covers with SM exhaust. I have removed mine but it's not a five minute job. Not all that bad but you need a ball end allen socket or ball end allen wrench for the socket head bolts. I think it'd require a swivel socket using six or twelve point fasteners. Twelve point wound be my choice. If you use six point bolts you're working space will be even more limited.
Originally Posted by payuppsucker
(Post 4191421)
I'm not too fired up about using power tools on a set of aluminum heads. I'll spend a few more minutes with hand tools. Installing helicoils or timeserts and extracting broken bolts isn't my favorite thing to do.
I have the angled valve covers with Lightning headers on mine with studs on the bottom which is the way to go as it holds the gasket in place. FWIW they also fit my JOMAR stud girdles and still go on and off very easy.
Going with hardin extreme or 2 piece, anybody have a set and willing to sell?
Thanks all, oso always a great resource |
I know the two piece have there application but if not need why pay the money or have a second place for a leak, I know the good ones are o-ring sealed, JMO
The 2 piece make access to valve train a simple job. The extremes make a doable job for access and any others make access to valve-train a nightmere!
| All times are GMT -5. The time now is 07:35 AM. |
