-   -   Secondary idle screw adjustment on quick fuel 1050? (https://www.offshoreonly.com/forums/general-q/318871-secondary-idle-screw-adjustment-quick-fuel-1050-a.html)
JRider 10-08-2014 10:42 AM
Ok, been poking around the web trying to find an adjustment procedure for secondary idle screw adjustment. I would assume this would be done in conjunction with the primary idle screw adjustment. I just guessed on how to do it last night when I started to tune my new carb.
FYI I am not talking mixture adjustment screws...I am talking secondary blade adjustments.
hullofjustis 10-08-2014 11:23 AM
what is it that you are trying to do? is it idling to high?
JRider 10-08-2014 11:37 AM
I am attempting to set the idle properly. This carb has secondary idle adjustment. I would assume that both primary and secondary blades should be set equally open but I do not know how to do that. I just eyeballs it last night.
hullofjustis 10-08-2014 12:01 PM
Was it purchased new or did you rebuild it? Generally you turn the one idle screw. On the throttle lever where the idle screw is there is a cam that turns the secondary lever.
The secondary does not open the exact same time as the primaries there is a slot in the throttle lever when the arm is pulled to the end is when the secondary throttle blades open
JRider 10-08-2014 12:38 PM
The carb is new. It has primary AND secondary adjustments for idle...I'm not talking mixture screws either. I am familiar with the linkage.
Black Baja 10-08-2014 01:03 PM
I usually give front and back 1/8 turn at a time till she idles right. If you go to far on the front blades and start getting fuel dripping from the boosters back the front blades out and try to get it to idle off the rear. It seems like the front booster like to drop fuel quicker than the back. It's ok to have the rear blades open more than the front or vise versa. When your messing with the adjustments after you make an adjustment crack the throttle a couple times and clean it out then let it come back down to an idle to see what you have...
MILD THUNDER 10-08-2014 06:40 PM
I set the primary side throttle blades so the transition slots are within spec. Secondary side, I close the blades completely, then give them 1/2 turn to just crack them. Fire the engine, if you need to raise or lower the idle speed, use the secondary screw..
Another thing Ive found, with tuning the idle mixture screws on a 4 corner idle carb. I've had complaints where guys couldnt get the lean sneeze out of their carbs when planing off. At low RPM, the signal is still very weak at the boosters, and it can still be relying on the primary idle circuit, to help fuel the engine while planing. While I know the instructions say to back each mixture screw out evenly all around, I've found having the primary sides out more than the secondary sides, helps with the lean sneeze. For example, if the best idle is with all 4 screws out 1 turn, try 1.5 turns in front, .5 in the back, or along those lines. For the most part, secondary idle circuits on holleys, are there so that in rarely driven hard classic cars, dont get stale fuel in the secondary bowl, or if you have some ridiculous cam in the engine.
Black Baja 10-08-2014 08:02 PM
Huh! Never thought of doing that with the mixture screws but makes perfect sense.
SB 10-08-2014 09:09 PM
Almost all Holley's have secondary throttle blade opening adjustment screws...it's just you have to take carb off and turn upside down to get to them. Pain in the nuts if you have to access them. A few come with normal screw as found on primaries.
Quick Fuel, and a few others, are just cool by giving you a normal type screw set up for them.
MILD THUNDER 10-08-2014 09:20 PM
1 Attachment(s)
I added them to my carbs. They are neat.:bigbird:
FIXX 10-08-2014 09:41 PM
i never touch the primary screw..reason is you can make the engine stumble if you are out of the idle circuit..
fbc25el 10-09-2014 07:43 AM
Is this a dominator or a 4150 ?
OPIE272 10-09-2014 08:49 AM
I adjust the primary butterfly with a mix of idle speed and mixture screws like all carburators.
My secondary butterfly I adjust to compensate for the RPM drop when I put it in gear.
If the idle speed drops too much in gear...I open secondary throttle plate 1/8-1/4 turn.
Adjust the primary idle plate and mixture again.
Go back and forth so that the idle is good in or out of gear.
I don't know if it's right. But it works for ME
JRider 10-09-2014 10:30 AM
4150
fbc25el 10-09-2014 10:45 AM
I think the main thing is not to over expose the transfer slots on either side. All you want to do is keep the transfer slot wet.
SB 10-09-2014 02:25 PM
Absolutely !
mike tkach 10-10-2014 08:45 AM
2 pages on how to adjust the idle,WOW
Black Baja 10-10-2014 10:18 AM
Going for 3. This was just on the curb idle don't forget...
SB 10-10-2014 10:53 AM
I had 2 seconds of idle time at work so I just logged on to this thread to catch up.
Are you guys screwin with us ?
I'm post whorin.
