86 350 Mag
I have water in #6. We had the heads done. Pressured checked the exhaust manifolds, risers and elbows. Replaced all gaskests. Checked #6 for any sign of a crack couldn't see any. If we start the engine and run it for a few minunites then shut it off # 6 fills with water. Cracked block or maybe a cracked intake manifold ?? Also put the pressure gage on #6 but it holds very little pressure. :confused:
Sounds like a cracked block or warped head(s).
The intake manafold has no water passages in that area, only at the front and rear ends are there water crossovers. |
Check valve springs. If you have a leak down tester use it. Could have warped exhaust valve. Which would drop cylinder pressure and pull in water.
just went through it,definetly a split cyl......we accually had to tear the engine down and bored the cyl which exposed a small hole in #4 cyl.....pull the piston out and put a whone in it if its a big crack the metal shavings will accually stick to the crack...this little rust spot turned out to be a dam whole,pressure tested everything,this was even a late model 330HP motor from GM.back in the late 80's GM used canadian casted motors,inwhich there was no real problem,until a few years go by.....turns out the castings were desighned to be thinner....lighter weight maybe,who knows!!!!!!!10 years old? you want to question the castings......
