-   -   Ebay water jacketed headers? (https://www.offshoreonly.com/forums/general-q/319314-ebay-water-jacketed-headers.html)
jmercer38 10-20-2014 01:30 PM
Has anyone tried these headers. Stainless like CMI for less than half the cost. I know I it says no classifieds but I'm not selling them myself but if someone has had any experience with them good or bad i would love to know.
http://www.ebay.com/itm/JET-BOAT-DOU...937332&vxp=mtr
I did email them and they said...
"We make these, they are NOT identical to CMI.... ours are made of 321 and 304 stainless. We also have some that are ceramic coated.... but these are not.
The biggest difference with these is the price point."
Anyone know about these? Are they a lower grade of stainless?
Thanks, John.
BUP 10-20-2014 02:08 PM
I think its a company in North Carolina that makes these headers for FTG Motorsports or maybe FTG owns them or vice versa. Its been talked about up here before. I even talked to the company in NC but do not remember their name at the moment. Maybe some can post the links about them.
BUP 10-20-2014 03:21 PM
here is who makes the headers.
www.xs-power.com/other-specialty-marine.htm
F-2 Speedy 10-20-2014 03:29 PM
I see five pieces in one tube, every place there is a weld its a potential leak, then you lost an engine, not being a downer, JMO, other headers are mandrel bent single piece tubes inner and outer, good luck
jmercer38 10-20-2014 03:38 PM
When these type of headers leak is it always at the welds?
F-2 Speedy 10-20-2014 06:45 PM
I've never owned a pair, so I cant say for certain, but any time your joining two pieces of metal together the human factor comes into play
BUP 10-21-2014 12:05 PM
no piece joining of anything is always stronger than 5 piece joining together, your material is only as strong as the weakest link. also welding together and or many seams in the material always will promote corrosion in those areas.
Budman II 10-21-2014 02:12 PM
I wouldn't be as worried about welded seams leaking on the outside pipes. If the inner pipes are mandrel bent instead of welded together they should be more durable. Of course, you still have areas like flange and collector attachment points that bring the human element back into play. Leaks to the outside are more of an annoyance than anything. It's when those inner pipes start leaking that you have big problems.
Budman II 10-21-2014 02:14 PM
No, the pipes themselves can crack from age and fatigue, especially if something happens to disrupt water flow and the inner pipes get overheated.
BUP 10-21-2014 08:47 PM
have no idea if this company inner tube exhaust portion is mandrel bent or not. I know Lighting headers are mandrel bent inner tube but pieced together welded on the outer tube portion - water jacketed side. If the seams from the welder have a lot of distortion and or porosity it will form corrosion over time. keep in mind the by products of combustion is corrosive all by itself. Combustion is a form of condensation and acids among other by particles (emissions).
Magnautic 09-01-2015 06:42 PM
Mine leaked right away, hydraulic lock and bent rods. How much does that cost? Seller said that it was not his problem and you could not get blood out of a turnip… XSpower hung up the phone when I explained the problem, tried calling back, goes straight to voice mail. During my conversation with the seller (FTG Motorsports) he stated that he had had 30% of the one’s that he had sold have the same problem, also stated that he has removed from web page, just checked, they are still for sale on his page. Don’t EVEN think about buying these headers, spread the word, don’t want anyone else to get burned.
