solid hub
I'm running a 496 HO "425hp" and I keep cracking the flow-torque hub. I'm also running on the OHIO RIVER. Should I use the solid hub? I'm concerned with small trash harming the drive instead of the nylon hub. THANKS! for your comments
I run the Delaware river and wouldn't even THINK about a solid hub:mad: . Outdrives are a lot more expensive and time consuming to repair or replace:( .
mopower what kinda HP and hub style are you using? I agree but I cracked the last flow-torque in one outing
| All times are GMT -5. The time now is 07:05 AM. |
