motor oils prefered on performance boats >
Old 10-26-2014 | 11:42 AM
Kendall 20-50 GT-1 Hi-Perf Racing Oil.
Donzi540 is offline
Old 10-26-2014 | 11:44 AM
Payton's Avatar
Charter Member #927
I've used Amsoil Diesel and Marine for the last 12 years in my 23 years old 454 Mags. The last 4 years small blowers added. 1 was torn down for the first time 2 weeks ago and the bearings looked like they could've been reused.I'm staying with Amsoil.
Payton is offline
Old 10-26-2014 | 11:50 AM
Don't use coconut oil because it turns solid below 65* and makes engine cranking a little difficult. Peanut oil is OK.
thirdchildhood is offline
Old 10-26-2014 | 11:54 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Message your crank wit dis . http://www.9thgencivic.com/forum/attachments/general-maintenance/167465d1394993262-another-oil-question-obama_snake_oil_salesman_wallpaper_g0dam.jpg
the deep is offline
Old 10-26-2014 | 11:56 AM
the deep's Avatar
Fast Singles Club
+1
the deep is offline
Old 10-26-2014 | 11:58 AM
peanut butter oil is best if you have peanut port heads.
mike tkach is offline
Old 10-26-2014 | 12:02 PM
i was amazed at how clean the insides of this engine was.usually an oil that contains a lot of zddp will have black deposits on the bottom of the pan.this engine did not.
Old 10-26-2014 | 12:13 PM
BUP
heavy deposits can come as to what group of an oil base it is - meaning Group I will leave heavy deposits, Group II a little better at not, Group III getting a whole lot cleaner, Group IV and V are your true syn based oils - Group IV is PAO base with possible slight ester mix and Group V is Ester based with possible slight POA mix these do better jobs at deposit control.
Also deposit control with oil changes in a correct timely manner. Also internal engine heat and a motor oil that can control oxidation play a role deposit control and helps with corrosion.
Also calcium additive in the oil helps for deposit control but its like everything - balance is the important key as you do not one additive to take away (strip) from another additive as they all have to do their jobs as well.
Amsoil does well for not leaving deposits.
BUP is offline
Old 10-26-2014 | 12:17 PM
That's definitely the stuff!
Old 10-26-2014 | 12:21 PM
SB
Actually, that Obama oil cleans too well.
Cleans the money out of your pocket.
Cleans your business out.
Cleans your house out.
Cleans your employee's money out.
Cleans your employees house out.
on, and on, and on,
Cleans everything right the fk out.
Edit in: Does seem to get keep your butthole well lubricated though. Lasts for years !
SB is offline
