540CI builds, MAX RPM? >
Old 11-09-2014 | 09:02 PM
a lot of good information here
C1000 is offline
Old 11-09-2014 | 09:31 PM
Last year I detuned a 540 with a 8-71 that was set to peak at 7900 rpm ,street car to marine duty ,had dart heads ,Merlin block ,quite a bit of run time and was wearing well .most people on the water will try to keep it well under 6k rpm though
airjunky is offline
Old 11-10-2014 | 03:58 AM
Originally Posted by JRider
My 509 dynod at 684hp at 6200...it did have very good heads though. I think he could make 700 at 6000 but I do not see a problem spinning it higher.
I just don't see it happening at 6000 with those heads. Gonna need some Rpm to improve the VE with a set of heads like that.
Black Baja is offline
Old 11-10-2014 | 05:59 AM
Full Force's Avatar
Maybe I need to fully work the heads I got, of I can I'm gonna... I was informed the pro comp heads worked can flow some good air.... All depends the $$ I got to spend
Full Force is offline
Old 11-10-2014 | 08:52 AM
On a 4.25" stroke-
66ft/s is ~5600rpm
82.5ft/s (roughly what a nascar mill spins) is ~7000rpm
Here's a kick ass chart showing the numbers for two high performance engines. Yours will spin slower, but proportionally so.
Cole2534 is offline
Old 11-10-2014 | 10:30 AM
offthefront's Avatar
Originally Posted by the deep
These are some of Bob Madara's words to me when I was considering building a 540ci . Coming from Bob you can take these words as gospel . " Your 700 hp target , from a 540ci displacement platform is absolutely doable . The majority of our 540 engine platforms are all dynoing between 685 and 725 hp , under 6000 rpm . The key components in making your target are going to be the induction system , cylinder heads and valve train . " I hope this helps to answer your question with information straight from the horses mouth .
Let Bob do his thing and you wont be sorry ........
offthefront is offline
Old 11-10-2014 | 10:40 AM
5400RPM max, went out with Tupac. Get in the game man! You rockin some peanut port heads and some cast chop suey cranks those mills?
MILD THUNDER is offline
Old 11-10-2014 | 02:50 PM
ROB FREEMAN's Avatar
Originally Posted by Full Force
what yours make and what rpm? details?
ROB FREEMAN is offline
Old 11-10-2014 | 02:58 PM
sweet video ic
Old 11-10-2014 | 04:26 PM
Full Force's Avatar
Hard to read Rob, any clearer pic?
Looks like you hit 700hp well before 6000? so anything in the 5500-6000 range is doable if parts are right... unless the fuzz is that fuzzy lol
