Fuel Pump and Filter mounting
Just purchaced a new Aeromotive 11108 fuel pump. Does anyone make a mounting bracket for this pump to the engine block? Currently, my water separator, fuel pump and Filter are all mounted on the back seat wall in front of the motor. I would like to move this whole setup to the motor if possible.
Electric pumps need to be mounted low. They are made to push fuel and do not pull well.
On the Merc 700sci they have a bracket that mounts the pump below the oil pan in front of the block.. (I think, judging from pictures). I also believe the AEO-11108 is the same pump as the merc one. perhaps that bracket will work. gets the pump nice and low. I was hoping someone had made a bracket though.. getting a hold of merc stuff is a challenge.
You could use a bracket like this, from a 525 efi. It's less than $60
http://www.mercruiserparts.com/Show_...nd+Fuel+Cooler It puts the pump under the balancer. You would have to drill some mounting holes in it, but that isn't a big deal. Eddie |
| All times are GMT -5. The time now is 07:21 PM. |
