-   -   Piston to valve clearance - 454 Mag short block (https://www.offshoreonly.com/forums/general-q/320454-piston-valve-clearance-454-mag-short-block.html)
TomZ 11-24-2014 08:17 AM
I tried to do some searching, but came up short.
Assuming a stock 365 short block, where does one start to run into clearance issues?
Let's say I were to run a Crane 731 roller... is it generally a matter of installing, degreeing it in per the cam card, and being done? I know that checking PVC is a must anyway (i know how and have the tools to do it), but the intent is to avoid having to go into the short block to make changes.
How much lift is safe and with what duration?
Thanks!
TomZ 11-24-2014 10:31 AM
Anyone?
vintage chromoly 11-24-2014 10:40 AM
You really need to mock up a cylinder and "clay" a piston to be sure.
Actual deck height and if the cylinder heads have been cut any can change things up.
TomZ 11-24-2014 11:49 AM
Yes, that would be the plan after a camshaft was in-hand. What I'm getting is in regard to parts selection beforehand. Looking for others experiences with this cam and similar.
I haven't removed the heads yet, but I have all the service records for the engine, and I'm dealing with a factory stock short block. I'll measure to be sure, but let's assume that the pistons are .020 below the deck, and dealing with an untouched cylinder head.
Black Baja 11-24-2014 11:54 AM
Thanks!
It's not really the lift an duration that's going to get you on a marine engine. When you go from say a 2.25 valve to a 2.3 with a 454 piston it will hit on the sides of the relief. Or if you go from a 2.3 valve to a 2.35 or 2.375 on the large bore Pistons. But that's a different story because with those kind of heads they are rolling the valve angle a couple degrees.
TomZ 11-24-2014 12:22 PM
In this case I'm not changing anything like that. My heads have the factory 26* valve angle. 2.19 intake and 1.88 exhaust. 118 cc chambers.
Black Baja 11-24-2014 01:56 PM
You should b fine
Budman II 11-24-2014 02:59 PM
Tom, I don't think you will have an issue with flat top or small dome pistons and a 731. I am running a cam with .596 / .612 lift and similar duration to the 731 with flat tops, and it wasn't even close to interference. No need to go larger than 2.19 / 1.88 with the relatively small bore of a 454 block, from what I have been told.
Black Baja 11-24-2014 03:05 PM
A big block is not like a small block when it comes to piston to valve clearance. I have .721@ the valve with no issues. That's with a 2.3 valve and a flat top.
TomZ 11-24-2014 08:37 PM
Thanks for the responses guys. Much appreciated.
