Originally Posted by ovrkil
(Post 4226283)
As a matter of fact I have a set of hitek headers....so that is covered. As for heads was going to use a set of procomps
Before you dig deep in this, do you have a planned budget in mind?
(Post 4226304)
well as i havent bought em it was just an idea....and i liked the price
Well i am hoping to be under 6g..
If you insist on el-cheapo heads see if liberty offers a set of big ford heads they are way better than projunk and builder price is cheaper as far as Chevy stuff goes. Not sure if they offer a Ford head yet. Keep in mind if you change the horsepower of the motor you are going to make the necessary adjustments to the oil and fuel systems as well. If you sit down and add it all up I think you would be way ahead buying another boat.
(Post 4226318)
Just to save you the headache here's what another member did with those heads...
http://www.offshoreonly.com/forums/g...recipes-3.html |
Yes, definitely a larger oil cooler so figure on about $600 there, new oil lines as a larger cooler most likely won't fit in the stock location (depending on whether you make them or buy them this can get pricey), new fuel tank pick up and lines so probably minimum of $100 there.
I wouldn't get discouraged, there are just alot of things to consider. Take a look at the whole picture and then make a decision. Is it worth going through all of it or just sell the boat and use your money for something that does 65 already?
Some people get overwhelmed and then never finish what they started. It definitely pays to know what your getting into from the start. |
Originally Posted by Black Baja
(Post 4226325)
Double that figure and you should be close.
| All times are GMT -5. The time now is 12:33 PM. |
