valve spring bearing
In some coil spring apps a thrust bearing is placed under one side of the coil to reduce friction and you end up with a more efficient combo.
Has this ever been tried with valve springs? Slap me if I'm waaaay off in left field. |
I have never seen a thrust bearing used on a coil spring... What application?
Rotators on old exhaust valve springs, that's all I've seen. Although I swear I did actually see one hack shop put them on the intake valves. Maybe he trained at cobra?
There's a BBC head that uses rotator on both intake and exhaust valves
Originally Posted by Black Baja
(Post 4227831)
On the fronts |
Under clutch springs for snowmobiles...LOL. But that's because these springs twisting/turning is part of the force used to tune the clutch. These clutches twist open and close.
BTW: Valves/springs/etc rotate without rotators/bearings/etc. http://www.youtube.com/watch?v=WtqDHJDN79w&feature=player_embedded |
(Post 4227831)
Originally Posted by SB
(Post 4227863)
Struts. Front ones.
Originally Posted by sutphen 30
(Post 4227852)
(Post 4227877)
I understand very well they use a bearing on top of front struts so the car can turn. But that's not what I got out of his description of a thrust bearing on the coil spring.
Oh, I thought you took valvespring and brought in coil springs in general. My bad. If you did mean coil springs in general, then I'll remain with my snowmobile clutch examples as others and I (in some clutches) use bearings in direct contact with the coil spring. |
I was thinking I'd seen them on suspension coils on a high end auto, BMW or MB maybe? Basically as the coil compresses it tries to rotate, but there's more resistance in compression or loading than unloading. By adding the bearing you get a smoother cycle.
I'ze just wondering if anyone had ever built some heads like that! |
Most of the overpriced junk Bmw and Mercedes I work on have air hydraulic suspension. Just curious cause I've never seen what you are describing.
Originally Posted by Cole2534
(Post 4227924)
Maybe I am just a crazy person. Lol, oops...
How are these springs rotating without a bearing and without wearing the head down?
https://www.youtube.com/watch?v=nsa6kq-qqIE#t=165 |
Good question. Is the valve rotating in its seat a little with each cycle?
| All times are GMT -5. The time now is 10:10 PM. |
