-   -   head gasket ? (https://www.offshoreonly.com/forums/general-q/320988-head-gasket.html)
MILD THUNDER 12-12-2014 03:03 PM
I believe the larger bore version is the same way. 1047 is the same as the marine 17048 gasket just different packaging
Panther 12-12-2014 03:12 PM
If using the 17046/48 style gasket I recommend spraying the gasket with Hi-Tack. It seems to help with sealing the lower water passages and there's less seepage down the side of the block.
mike tkach 12-12-2014 04:17 PM
i have used the 17046 many times with great results.i never use any sealant on them.just stating my experiance.
sutphen 30 12-12-2014 08:38 PM
i used to do that,a long time ago.now I just cometic gaskets,,problem solve.plus deck surface RA is critical.
actionmarineguy 12-16-2014 11:16 AM
Still no answer?
Called cometic, they said the same gasket is used on all 3 gen of big blocks with no modifications, I don't see how that can be
Also checked the head contact at fire ring, Good tip.Thanks
sutphen 30 12-16-2014 06:37 PM
you can still get the mark4 head gaskets
http://i60.tinypic.com/24n06km.jpg
sutphen 30 12-16-2014 06:39 PM
does look like they have a 1 size fits all.
http://i59.tinypic.com/2mgl5w7.jpg
actionmarineguy 12-17-2014 09:37 AM
But still not sure if you have to drill holes in block or not? as described by fel pro
All gaskets I find have either one hole or two holes in the end of the gasket for the mark IV
All new gaskets have holes between the cylinders under the head bolts where they tell you to make the hole
My old gaskets had two holes on the end and No holes under the head bolts between the cyl.
My best guess is to make the holes in the block as described by fel pro. Hope this is not a mistake
MILD THUNDER 12-17-2014 10:04 AM
I have mark iv blocks with dart aluminum heads. I never drilled any holes. I've used the felpro 1071-1 , cosmetic C5329-050, and victor reinz solicor head gaskets on these engines with no issues.
sutphen 30 12-17-2014 12:14 PM
drilling of the 3 lower holes is for really early blocks.very noticeable when the head gaskets are put on.
