-   -   Different size headers (https://www.offshoreonly.com/forums/general-q/321213-different-size-headers.html)
hadleycat 12-17-2014 09:44 PM
1 Attachment(s)
The Header on the left of the picture is my everyday port-side use header. I have a matching starboard-side Header that I run on the boat.
The Header on the right of the picture is the port-side Header I put on for tuning. It has an O2 bung welded into it. I do not have a match for it. The primary tubes on this header are 1 1/2" longer than the primaries on my starboard header.
My question is, Am I hurting the motor by running a mismatched set of headers. Also would this effect my 02 readings.
[ATTACH=CONFIG]534543[/ATTACH]
ezstriper 12-18-2014 08:25 AM
I don't think effect the 02 readings, and not all headers have the same length tubes anyway, probably never see a difference...just would change the torque curve slightly I would think
SB 12-18-2014 08:35 AM
More importantly, Make sure the primary ID is the same and the collectors are identical ID and length.
hadleycat 12-18-2014 08:35 AM
Yeah even on the same header each tube is a little different in length. On manifolds I think the differnce between cylinders is even more.
hadleycat 12-18-2014 08:41 AM
Yes on both accounts.
SB 12-18-2014 08:44 AM
I'm more picky than the next guy when it comes to exhaust tuning, and if I had your system I'd be fine with that.
ezstriper 12-18-2014 03:49 PM
Only the more expensive headers are true equal length...marine ones very doubtful
hadleycat 02-03-2015 02:34 PM
Thank you for the replies guys
