-   -   Help with Sender???? (https://www.offshoreonly.com/forums/general-q/32147-help-sender.html)
daveo1 09-02-2002 09:24 AM
I am going to be installing a fuel pressure gauge on a 7.4 mpi (1999) and I need help with where to plumb the sender. There is a service port (shrader valve) on the front of the motor by the intake manifold and that looks looks a good place. Has any one ever done this? does anyone know where I can find a fitting/ adapter to utilize this valve for a sender? any help would be appreciated...
FindMe 09-03-2002 02:27 AM
Mercruiser bulletin
Here is some info from Mercruiser about fuel pressure gages and hookups. Not sure if it applies to what you are doing, but maybe. This is from a factory service bulletin, with Merc part #'s. Hope this helps...
Fuel Pressure Gauge Kit
1998 MCM/MIE 7.4L MPI uses a different size and type of ‘test port’ valve on it for checking the fuel pressure at the fuel rail. The current Fuel Pressure Gauge Kit (P/N 91-16850A 2) will not attach to this valve. A new kit is superseding this kit and it will contain 2 fittings so it will fit both types of ‘test ports’ and a TBI pressure valve to allow the gauge to connect to TBI engines. Quicksilver will also sell an Adaptor Kit that can be purchased to update the older 91-16850A 2 kit. This kit comes with both size ’test port’ valve adapters and instructions on how to fit it to the older gauge kit.
91-16850A 3 Fuel Pressure Gauge Kit. Kit contains Adaptor Kit and TBI Pressure Valve.
To update older 91-16850A 1 or A 2 Fuel Pressure Gauge Kit, order the following.
91-806901 TBI Pressure Valve. Allows older Gauge Kits to connect to TBI engines.
91-803135 Adaptor Kit. Allows older Gauge Kits to connect to either type of ‘test port’
valve.
