Havent seen one either . Or an explamation why the bbf super cobra jet intake works so well on the std port heads .or if my 088' with 2.25 intakes are going to work as good as tom's heads.do the 525 heads have the same exhaust valve p/n as the std 502 mag?
Definetly havent seen a blower on a set of gmpp crate 502 aluminums or eddys aluminum ovals . Not sayin its never been done
Holley/weiand makes one. It's pretty $$ though, and probably not worth anything for what you're doing. I used one years ago on a 525sc with eddy marine heads.
Good to know thanks Mild. I didn't really look for one once I was told that it wouldn't matter.
Originally Posted by HaxbySpeed
(Post 4258058)
They are not cheap manifolds that's for sure. I know many have ran rectangle port intakes on oval port heads and it works. However I've never seen any data on if switching it for a port matched intake is worth power.
I have a slight mismatch from my rect intakes to rect heads as the ports are slightly different shape. It drives me nuts knowing its like that lol. Sooner or later I plan to pull them and do a nice port match. I wouldn't be able to sleep knowing I have a big rectangle port intake on an oval port head. Have you seen any hard data that "it doesn't matter" for your application ? |
Originally Posted by ealesh33
(Post 4257742)
I have A 177 weiand blower, your traditional intakes won't work. I haven't looked very hard for intakes as I was told by my builder and Bob that I won't see a difference in my application, but I haven't seen an oval port intake that accepts my blower
Originally Posted by MILD THUNDER
(Post 4258127)
(Post 4258127)
| All times are GMT -5. The time now is 04:31 AM. |
