-   -   Procharged 502 Mag Oil Cooler Recommendations (https://www.offshoreonly.com/forums/general-q/321962-procharged-502-mag-oil-cooler-recommendations.html)
justinp20012500 01-12-2015 07:48 AM
I searched and searched, nothing I found could help...
Winter upgrades will include installing a couple of new M1-SC (with associated upgrades & programming) to two 502 MAGs.
I know there are many items that are needed for the 502's to live a long, happy, healthy life so I am compiling some necessary info. The first being upgraded oil coolers.
What is available? Does anyone have any recommendations? These are going in a confined engine compartment of a BAJA BOSS 302.
I am already dealing with slight oil pressure drop at or near WOT for any extended period due to rising oil temps.
Black Baja 01-12-2015 07:59 AM
Call Mr. Cool great prices quality pieces.
ezstriper 01-12-2015 08:33 AM
I used a eddie marine large cooler, block adapter, filter mount and #10 lines, the merc stuff is junk, need to redo fuel system as well to make live with the procharger...
justinp20012500 01-12-2015 08:53 AM
Planning on it. Going to pull the rails and send them to Eddie Young to be modified.
What is anyone's thoughts on using this adapter for a wide band 02 sensor?
http://www.ebay.com/itm/310137061646...%3AMEBIDX%3AIT
Have something better?
liquidlounge 01-12-2015 11:36 AM
I did not have good luck with Mr. Cool. Sent me exactly what I told him I didn't want and then would not return my phone calls. I would place him in the "scheister" category.
GPM 01-12-2015 03:55 PM
Maybe one of these would work for you, http://www.cpperformance.com/c-731-t...l-coolers.aspx
hadleycat 01-12-2015 04:04 PM
I am also shopping oil coolers for my M3 Procharged 502. Last year I ran the stock oil cooler. With no thermostat my engine runs around 110 degrees water temp. My oil would never warm up above 110 degrees until I ran the boat hard. For that reason I am considering one of these. http://www.cpperformance.com/p-26867...k-adapter.aspx
Young Performance 01-12-2015 06:52 PM
The thermostatic adapter the Hadley referenced is a great choice. We have used quite a few of them. There were some issues with the first few, but they have that worked out now.
As for a cooler, a cooler with a 3" x 12" bundle from Hardin will do just fine at that power level. A cooler with a 3 x12" bundle will be about 16" long overall. That will cool up to 700-750 if you run it really hard, and quite a bit more if you only run it really hard periodically.
Eddie
hadleycat 01-13-2015 09:15 AM
Eddie
Thanks for the Cooler size info Eddie :)
justinp20012500 02-06-2015 10:45 AM
I am having Eddie do my fuel system which requires the elimination of the cool fuel and pump.
Is there an oil cooler that can go in place of the cool fuel? I will pick up the thermostatic adapter to run with one if I can get it to fit.
Seems like a good location.
hadleycat 02-06-2015 06:10 PM
I plan on putting my new cooler in that same location. I purchased 2 of these http://www.cpperformance.com/p-13327...r-bracket.aspx to hold the cooler to the existing cool fuel bracket. I am sure it will involve some cutting and grinding on the existing bracket. I recieved my new cooler and it is monstrous compared to the tiny fuel cooler.
tbanzer 02-06-2015 07:16 PM
What cooler did you end up with?
hadleycat 02-06-2015 08:39 PM
If you were asking me I purchased a 3" X 16" from CP Performance
tbanzer 02-07-2015 06:16 PM
Yes I was Thanks. I am in the process of doing similar mods myself, both to the fuel and lubrication systems. The $$$ add up fast!
justinp20012500 02-07-2015 07:06 PM
So you will utilize the water line that once ran through the cool fuel?
When you get it done will you snap a few pics?
I am still a month away from tearing down.
justinp20012500 02-07-2015 07:44 PM
Duplicate...
hadleycat 02-08-2015 05:14 AM
Yes I will.
hadleycat 02-22-2015 08:55 AM
3 Attachment(s)
[ATTACH=CONFIG]537444[/ATTACH][ATTACH=CONFIG]537445[/ATTACH][ATTACH=CONFIG]537446[/ATTACH]
Mounted the cooler today. Fuel Cooler bracket works great for this. Even the factory holes lined up for bolting on the Stainless mounts. Only fabrication left to do is weld a couple of the unused factory holes shut just because I am being picky.
hadleycat 02-22-2015 08:59 AM
3 Attachment(s)
[ATTACH=CONFIG]537447[/ATTACH][ATTACH=CONFIG]537448[/ATTACH][ATTACH=CONFIG]537449[/ATTACH]
justinp20012500 02-27-2015 09:36 AM
Looks excellent, that is exactly what I was thinking!
justinp20012500 09-21-2015 12:54 PM
Do you think there would be any issues placing a cooler that is 19" in length where the cool fuel went?
