Click on here: http://www.racingsprings.com/Multime...b/kb513102.pdf
And look at the section of heat vs valvespring psi changes as installed. Oil cools your valvetrain. Use plenty of oil and make sure your oil cooler keeps it to the correct temp. |
need the cooling to valve springs...in drag race engine not run long enough to be a issue...
oil cools and carrys the heat back to the cooler to release the heat into the water and out the system.
Originally Posted by ezstriper
(Post 4257673)
A friend called me and asked about oil restrictors,he was told he needs them, it is a solid roller motor. The instructions say on the lifters not use restrictors.
Originally Posted by Craney
(Post 4467773)
(Post 4467773)
bad idea on a boat
Originally Posted by compedgemarine
(Post 4468035)
so I think this all comes down to, is your friend going to listen to some guy who told him to use restrictors or the people who designed and built the lifters he is using.
| All times are GMT -5. The time now is 07:02 PM. |
