-   -   horsepower estimate (https://www.offshoreonly.com/forums/general-q/322702-horsepower-estimate.html)
Satisfaction 02-02-2015 07:28 PM
horsepower estimate
any one have any idea on how much this hp this engine with make?
509ci 9 to 1 compression ratio
AFR 315cc heads 741 roller cam
Holley dominator carb
30ftpanther 02-02-2015 07:40 PM
647?
mike tkach 02-02-2015 07:40 PM
582.3 by SWAG.
tpabayflyer 02-02-2015 09:45 PM
What exhaust do you have?? I would say mid 600 range with torque out the wazoo!
sutphen 30 02-02-2015 11:58 PM
Originally Posted by mike tkach (Post 4259482)
582.3 by swag.
587.8 would be my guess.
Bawana 02-03-2015 12:02 AM
What the F is SWAG?????
Jfoster 02-03-2015 12:50 AM
I just did a similar build last week but with stock 088 heads and a Holley HP 1000 cfm carb. i used car exhaust on the dyno and made 580 hp and 620 TQ at 5300 RPM
dereknkathy 02-03-2015 04:36 AM
it is custom software for calculating anything at all. very similar to GIGO...(garbage in garbage out...simple wild a$$ guess.)
Black Baja 02-03-2015 05:12 AM
My guess is a lot more if you get rid of that cam that is all wrong.
Rattlesnake Jake 02-03-2015 06:48 AM
585.2
Satisfaction 02-03-2015 09:45 AM
Cmi headers
JRider 02-03-2015 10:59 AM
Why is the cam "all wrong"?
sutphen 30 02-03-2015 12:57 PM
your right,,why get a cam thats proven to work,,should get a real good bump stick from the worlds worst cam guy,,my buddy cslob.
Satisfaction 02-03-2015 01:06 PM
I understand that I could make more power with a custom cam built for my specs. But at the same time I believe it could make pretty decent power with most likey the best out of the box cam.
CrownHawg 02-03-2015 01:13 PM
I would guess more HP and torque than a Alpha can handle.......
sutphen 30 02-03-2015 01:23 PM
I pesronally doubt it,moving the the cam degrees and calling it custom is not going to change hp all that much.you jump the cam degrees 6-10degrees,then you going against a different cam for way more hp.custom cam is going to net you anything you'll feel in a boat.
you pick a hp goal and alot of cams will get you there.
rmbuilder 02-03-2015 01:45 PM
With a AFR 315 head combination there is an easy 25 HP available.
Black Baja 02-03-2015 03:07 PM
Was Straub ever mentioned?
Black Baja 02-03-2015 03:19 PM
I don't think it would be money well spent to spend all that money on a nice set of heads and put the wrong cam in the motor. Not only will it make less power on the top end. But it will be sluggish. Add a Carburetor that is entirely too big and it gets even worse.
HaxbySpeed 02-03-2015 04:04 PM
BB, I actually thought you were being sarcastic with your first post. I don't think the 741 is way out of line for this build. My only thought would be that you could make the same, or more power with a more modern lobe design that is a little easier on valve train parts. if I already had a 741 though, I'd probably run it. I'm going to guess 635 if you've got your valve train sorted.
mike tkach 02-03-2015 08:51 PM
scientific wild azz guess.
MILD THUNDER 08-06-2015 08:43 AM
The 741 is an agressive lobed cam compared to what? I know of at least a dozen engines that have ran that cam past 300 hours without issue. Also, many have used that cam and made very good power for an off the shelf marine cam. With everything from 088 heads to afr 315s ..etc.
In certainly no cam expert but id be willing to bet the lobes on that 741 are alot easier on the valvetrain than these .681, .697 , +400 lobes that have the same or similar .050 duration numbers.
The crane merc 525efi cam is fairly similar to the 741 grind, and a buddy just freshened his 525s in his 37 active thunder that had 500+ hours. No issues at teardown.
buck35 08-06-2015 09:35 AM
So what did it make? Did it get built.
ezstriper 08-06-2015 10:30 AM
while we are talking about this deal, I think the dominator is way overkill for this....
