-   -   marine sealant (clear) (https://www.offshoreonly.com/forums/general-q/323183-marine-sealant-clear.html)
chaoscube 02-17-2015 08:52 AM
I just bought a pair of swim step and I was wondering which Clear Marine Sealant I could use to seal all around the brackets with the transom. I know the best stuff is 3M 4200 or 5200 but these products are not available in the Clear finish. I will put some marine epoxy on the exposed wood before installing my bolts. Any idea about what good clear sealant I can use (below water line) ? No problem to find white or black stuff but I really want a clear one.
Thanks.
Knot 4 Me 02-17-2015 08:57 AM
Check out Boatlife Life Seal.
ezstriper 02-17-2015 10:37 AM
I use the clear 100% silocone from DAP lowes carries it...great stuff...I do not think there is anything to "marine" silocone...the 3M are sealer adhesive, 5200 when you do NOT want to remove, neither really what you are looking for and they are messy to work with as well and tend to "run" on a vertical install
HyFive578 02-17-2015 10:46 AM
I use Permatex Clear RTV for sealing around exhaust tips.. Should be fine for your application as well
http://www.permatex.com/products-2/p...sealant-detail
http://static.rshughes.com/wm/p/wm-a...0f3efc.pdf?uf=
HyFive578 02-17-2015 10:48 AM
I just reread your post and see you want below water line. The BoatLife LifeSeal might be better..
chaoscube 02-17-2015 02:23 PM
I can't find any BoatLife dealer in Canada but will probably import the products on the internet.
Thanks a lot !
chaoscube 02-19-2015 07:59 PM
I have found this locally :
http://www.starbrite.com/item/marine-silicone-sealant
Anybody used or know this product ?
Knot 4 Me 02-20-2015 09:16 AM
Sounds like it would work for you.
US1 Fountain 02-20-2015 10:38 AM
A little explanation of sealants. I read the differences before as far as when compared to your home hardware stuff, but couldn't recall specifics.
Silicone around the 3:30 mark
https://www.youtube.com/watch?v=G-aQ...ature=youtu.be
chaoscube 02-20-2015 01:28 PM
Nice video ! I have found a canadiAn retailer for boat life life seal... I will use this product.
