Cleaning vinyl?
Cleaning vinyl?
Can anyone recommend a good cleaner to clean white vinyl seats and sun pad? I tried black streak remover, Attwood vinyl cleaner and Soft Scrub. The first two didn't do much. Soft Scrub did remove some of the strains but not everything.
I have amazing results with "awesome orange" and a green "scotch-brite"scrub pad. It gets out grease, oil, mold, mildew, and other stains. Others have good luck with "simple green" or a "mr clean magic eraser." No matter what you use to clean it make sure you treat it with a good vinyl protectant after to seal it. I use "303" marine vinyl protectant, a little pricey but it is good quality stuff and cost is offset by the dollar bottles of the cleaner. Hope this helps I am sure others with chime in there are hundreds of posts about this use the search tool.
21 and 42 footers
Thanks for all the suggestions!
