Optimal Squish
What would be the optimal squish range for a 454 NA build? AFR cyl. heads 10 to 1 compression.
Thanks Jeff |
With good parts .035 would be safe.
Originally Posted by sbslinde
(Post 4273235)
Thanks Jeff |
No blowers for me. Can't afford what I have now.
.040
Keep in mind that .035 is the minimal safe piston to cylinder head clearance. I like a little more of a safety margin myself... mine will go together at .044 (piston .005 in the hole and a .039 gasket). But then again, mine will be blown so a tight quench isn't really necessary.
Just my thoughts... by far no expert.... just my experiences. |
Originally Posted by TomZ
(Post 4273319)
Originally Posted by Black Baja
(Post 4273322)
I've got less than that on my 632
quench/squish supports combustion process by squeezing the charge into the chamber where the spark occurs, also has a cooling effect as the quench area runs cooler than the rest of the combustion area... this will allow for a higher compression ratio to be used and aid in the quality of combustion achieved... properly designed quench is like upping the octane, promotes a better burn!!
"Zero" decking the block will allow tuning quench with the head gasket, the proper spec for desired quench is a debate that's been around since Chrysler was a cowboy!!! compression ratio and chamber design are factors but on average .035-.060 what I've seen in the field
Originally Posted by adk61
(Post 4273361)
But why tighter than the recommended safe clearance? Some say that for very tight quench we want the piston to "just about" kiss the cylinder head surface, but others say that there are diminishing returns or even the chance of promoting detonation (especially in power adder applications... blowers, N2O). Some very well known builders go so far as to say that tightening the quench below .050 on a BBC is a waste of time. |
FYI I'm running .060 on my 1100sc engines
(Post 4273342)
Less than the minimum? If so, can you elaborate on why? Mine at .044 is still considered tight. Books and articles I've read on this subject say that the tighter than the minimum isn't necessary. Just trying to understand is all.
This is an older thread with some great information by Haxby.
http://www.offshoreonly.com/forums/g...ch-thread.html |
| All times are GMT -5. The time now is 06:31 PM. |
