-   -   Assault heads (https://www.offshoreonly.com/forums/general-q/323666-assault-heads.html)
bigboat28 03-04-2015 12:52 AM
Assault heads
Anyone ever used these heads? Good or bad results? Thoughts on these heads?
Black Baja 03-04-2015 05:23 AM
I'm not a fan of parts made in China.
Full Force 03-04-2015 05:26 AM
5 Attachment(s)
Stay away from non name brand heads, I would hope you learned from the mess I inherited, you get what you pay for and after seeing the AFR I just got yesterday I would not even think about going a cheap head.....
[ATTACH=CONFIG]537920[/ATTACH][ATTACH=CONFIG]537921[/ATTACH][ATTACH=CONFIG]537922[/ATTACH][ATTACH=CONFIG]537923[/ATTACH][ATTACH=CONFIG]537924[/ATTACH]
Full Force 03-04-2015 05:29 AM
3 Attachment(s)
Chinese Pro Comps look at the port if you can see it, wish I had pics inside Pro Comp ports.... they suck for flow compared to name brand...
[ATTACH=CONFIG]537925[/ATTACH][ATTACH=CONFIG]537926[/ATTACH][ATTACH=CONFIG]537927[/ATTACH]
turbo2256b 03-04-2015 08:06 AM
Cheep heads can have many issues one nort often discussed is porting them is a pain as the metal is a bit gooy clogs up the bur quickly. Gets to be a pain picking the material out of the burr.
adk61 03-04-2015 09:05 AM
WD40 on the burr
sutphen 30 03-04-2015 09:09 AM
Originally Posted by adk61 (Post 4273719)
WD40 on the burr
I dip the cutting bits in transmission fluid.
SB 03-04-2015 09:09 AM
WD40 on the burr
Works good on the aluminum but not so much for the piece of ham sandwich stuck in the casting.
Cole2534 03-04-2015 10:25 AM
WD40 on the burr
God's gift to cutting Al.
ezstriper 03-05-2015 09:29 AM
I would be as much worried about the junk a$$ valves breaking off(which has happened) and destroying everything as the heads being basic POS themselves...
