-   -   496 Mag HO water circulation problem (https://www.offshoreonly.com/forums/general-q/323872-496-mag-ho-water-circulation-problem.html)
Baja Rooster 03-11-2015 04:13 PM
In a thread jack, is there any reason to keep the recirc pump? I have both the sea water pump and the recirc pump on my 502, but I've noticed that most boats run a bypass and get rid of the recirc pump.
APEXrtx06 03-12-2015 12:16 PM
I've never heard of anyone eliminating/bypassing the recirc pump... Curious about this now!
Dave M 03-12-2015 12:28 PM
496HO? Are you sure the water drainage system is fully closed? Sometimes those little green tabs get stuck.
APEXrtx06 03-13-2015 11:13 AM
Well, after all this I might just be an idiot...lol. I took the water pump apart last night and apparently I did not put in the front (toward pulley) wear plate. I haven't re-installed the pump yet but hopefully that will take care of it. I'll be installing it and firing it up later today.
BUP 03-13-2015 12:34 PM
If you took the water pump housing output hose off surely we have seen that NO water was being pump thru the housing or very little water was being pumped. That is always the first test to do to see if you get water flow. If no water flow or not enough volume then its time to start back tracking starting at your first point - The impeller and water pump housing.
APEXrtx06 03-14-2015 11:23 AM
Ok, it worked! Thanks for all the help everyone!
