You may have to reset your smart craft gauge to either ignore the error or change a setting.
Pull out your smart craft gauge manual/guide as it may help you with this or go through the gauge settings. |
Totally agree 100 % about going thru with resetting the configurations on your smartcraft gauge now after knowing what you have. .
here is the smartcraft sensors and harnesses to look at
Look at PART #9 100 psi Pitot sensor just an FYI if your app was using it as you said everything was disconnected. Also some performance boats will use a 200 psi Pitot sensor as their speed is above 80 mph. The 100 psi Pitot sensor is for speed readings 0 thru 80 mph. Just some more info. Like I asked if you have DTS because a lot apps with DTS and Smartcraft especially the 496 used the Pitot sensor & harness connections. Also like I said DTS apps are different than mechanical shift apps. Link below for whomever FWIW .http://www.marineengine.com/parts/me...-and-harnesses |
| All times are GMT -5. The time now is 06:22 AM. |
