Bravo Swivel Shaft replacement/parts questions
I have play in my upper swivel pin on my Bravo one. From all the good feedback on the J&R Marine repair kit I am going to go that route. Other than buying his swivel shaft cover plate kit, what other parts should I replace while I have everything apart? I figured the shaft and u bolt from J&R. What else should I replace???
Thanks for any recommendations |
I don't know what the kit comes with, but the shaft seal and bushing should be changed.
When you call JR they will let you know everything you need. Most likely your gimble ring is worn also. They can repair this as well.
Thanks for the help.
I tried to call J&R Marine but they are closed till April 8th. I was hoping to start this before than. |
| All times are GMT -5. The time now is 09:58 PM. |
