-   -   wix oil filters (https://www.offshoreonly.com/forums/general-q/324289-wix-oil-filters.html)
35fountain 03-21-2015 12:23 PM
wix oil filters
I have been using the Wix 51060R. It says for racing applications only. What exactly does that mean?. I noticed on the Wix 51060 standard filter everything is the same accept the Fl;ow Rate GPM. The 51060 has a flow rate of 9-11 GPM and the 51060R has a rating of 28 GPM. Is that the only difference.? How much oil does my engine pump? It only holds 8 quarts. Wouldn't a standard Wix 51060 be ok?
Just wondering
sutphen 30 03-21-2015 12:37 PM
R flows more because it lets bigger partcles by,size that Apollard can see w/ the naked eye.:)
and the non R will be fine for your engine.
35fountain 03-21-2015 04:00 PM
Thanks, I just order a case of them
ezstriper 03-22-2015 09:15 AM
The NAPA gold is the same wix non racing filter...easier to find around here
35fountain 03-22-2015 09:31 AM
Just got a case of 12 for 43.44
http://www.discountfleetsupply.com/wix51060.html
CIG3 03-25-2015 02:50 PM
If you want more capacity you can run 51794 which is the same filter but taller (2 quarts).
With stock power the non-R filter is more than fine. With that flow rate you are filtering your oil approx. 2x per minute with a 5 quart pan.
dcb 03-25-2015 03:16 PM
Carquest carries the Wix racing filters.
1989mach1 03-25-2015 04:59 PM
Would the R filters be better for the 500efi's. Looking to change to them this year from the merc ones
CIG3 03-26-2015 06:57 AM
You will be fine with the Non-"R" filter on your 500HP. Better filtering and more than adequate flow
1989mach1 03-26-2015 07:34 AM
Ok thanks
thirdchildhood 03-26-2015 01:00 PM
So does NAPA. I'll keep running the R filters, they really don't cost that much.
dunnitagain 03-26-2015 08:11 PM
Unless you running large volume dry sump oil pumps , that need the volume ( GPM ) .
I wouldn't run the R filter. The micron rating isn't low enough to filter your oil effectively .
The R filter is for someone that changes there oil very frequently ( such as a race engine ) .
You will be hurting yourself in the long run. Someone mentioned the 51794 ( 2 Quart Filter )
That's what I would run if you can fit it, the filter media is about twice as long as the 51060.
Less pressure drop , more flow , increased filtering capacity. Ive used the 51794 on 800HP Sprint Car Engines
without any issues. Buy a filter cutter from Jegs or Summit and look insde the different brands , you'll get an education!
bonesmalon 03-26-2015 08:15 PM
Ditto. I came to the exact same conclusions. Buy the NAPA...save money...save your motors.
thirdchildhood 03-26-2015 08:51 PM
I've seen the filters cut apart over and over and just recently in a thread. I've also seen all of the threads endorsing the "R" Wix. Like most of us, I change my oil 2 or 3 times a season. Hmmm, maybe it's time for a poll.......
1989mach1 03-26-2015 09:40 PM
I just got 4 of the 51794's I like the idea of the better filtering yet bigger for better flow so I gess we will see how they work out.
