-   -   Head Gasket Replacement Cost (https://www.offshoreonly.com/forums/general-q/324870-head-gasket-replacement-cost.html)
mummaiv 04-07-2015 10:54 AM
What would the average cost be to replace the head gasket on a 496 HO?
Blueabyss 04-07-2015 11:21 AM
Is it in the boat or out of the boat?? It will cost a lot.. The head bolts are not reusable and are expensive. In the boat I would guess 1500-1800.00
mummaiv 04-07-2015 11:24 AM
The the boat...
Griff 04-08-2015 01:43 AM
If one head gasket let go, you should be replacing both of them and doing a valve job and possibly springs at the same time.
Probably 3k or a little more.
jeff32 04-08-2015 05:52 AM
Springs on a 496?
boatnt 04-08-2015 08:55 AM
head gaskets is not a common failed gasket in a 496,,car or boat,, what does the oil look like?
you might want to flush out the coolant system and add oil dye to the oil ,,run the boat and see if you get and dye in the coolant bottle.
mike tkach 04-08-2015 08:57 AM
why does it need a head gasket?is the head gasket the root problem or a secondary one caused by something else?
mummaiv 04-08-2015 08:59 AM
Not sure it does need one... In the process of purchasing the boat and noticed the coolant tank was no longer clear and is much darker in color than the starboard tank.
