-   -   What goes here? (https://www.offshoreonly.com/forums/general-q/324947-what-goes-here.html)
Cole2534 04-09-2015 12:11 PM
What goes here?
What should I use to plug port side valve cover vent?
http://i1151.photobucket.com/albums/...psgse657y6.jpg
buck35 04-09-2015 01:29 PM
I believe that is a vent to your flame arrestor.
Cole2534 04-09-2015 02:10 PM
on the starboard side it vents to the manifold, on the port side it goes nowhere.
Suggestions?
MILD THUNDER 04-09-2015 02:16 PM
Pcv valve
Cole2534 04-09-2015 02:49 PM
Do you plumb the PCV to anything? It seems like it was just left open by merc.
Griff 04-09-2015 03:26 PM
1 Attachment(s)
PVC valve and hose connects to fitting on front underside of upper intake
Other side connects to flame arrestor
Diamond Dave 04-09-2015 03:37 PM
That's a nice looking engine you have there!
Cole2534 04-09-2015 08:21 PM
Thanks Dave.
I don't have the factory flame arrestor. Can I tee it into the hose for the other?
Randy Nielsen 04-09-2015 08:53 PM
I have an older style mpi manifold that tee'd both vents together then into the manifold but the tee was a funky plastic piece that was merc only I'm sure.
F-2 Speedy 04-09-2015 09:31 PM
Hey Cole, what kind of power did it make, it is a custom tuned ECM right ??
airjunky 04-09-2015 09:34 PM
Trying to cobble together a bbc cast valve cover analogy that parallels buying a pair of shoes getting home and they are both lefts . All you can do now is get blowby (hopefully minimal) out through 502 mag specific fitting and back over somewhere where it re enteres the engine goes out the exhaust and you never smell or see it.
thats all that really counts unless they do a visual smog check where your at.
have to watch those bbc alum valve covers if your going custom . They all kind of look the same at first glance but ...
Cole2534 04-09-2015 10:37 PM
I got a Bridgeport and a Monarch, nothing is proprietary. :)
It was roughed in on the dyno and made 497. We'll fine tune it in the boat.
FIXX 04-10-2015 01:48 AM
On most models merc tied port and starboard together then it ran to the bottom of the flame arrestor..it would rely on the suction of the throttle body to suck the crankcase clean..
dereknkathy 04-10-2015 05:41 AM
problem with PCV is at high throttle there is no engine vacuum. and more blowby. that is why it is put into flame arrestor. PCV is fine for sportfish that spend their lives at part throttle. but a high perf engine needs blowby routed straight to intake air. although you seem to only smell blowby at no-wake speeds. that is when having PCV also is nice...
f_inscreenname 04-10-2015 10:13 AM
If it goes to the flame arrestor it's not a pcv its just a plastic hollow pcv looking thing with no spring and guts inside that fits the valve covers hole. If it goes to the back of the carb or intake then it uses a real pcv valve.
Cole2534 04-10-2015 10:36 AM
As long as it vent to the intake and not my bilge compartment, I'll be a happy camper.
dereknkathy 04-10-2015 05:35 PM
Best way to go is PCV to manifold vacuum on 1 side and straight vent hose to flame arrestor on other side.
lakematdude 04-10-2015 05:43 PM
Between the links below would be all the OEM parts that completed the stock set up.
http://www.mercruiserparts.com/Show_...d+Rocker+Cover
http://www.mercruiserparts.com/Show_...+Intake+Plenum
^^^, The parts above would of had the hose connect to the flame arrestor which started in 1997. 1996 Merc used item number 31 which would allow the vent hose rest just on the under side of the flame arrester.
http://www.mercruiserparts.com/Show_...D+ROCKER+COVER
http://www.mercruiserparts.com/Show_...+INTAKE+PLENUM
^^^, Same with 1993-95 as 96 but different hose routing,
SB 04-10-2015 06:36 PM
Here's the pic:
http://www.mercruiserparts.com/images/COMMON/39677.png
dereknkathy 04-10-2015 10:00 PM
is that an actual merc diagram? big block valve covers on small block heads?
Randy Nielsen 04-10-2015 11:50 PM
Yep, #30 combines both crankcase vents to single hose that connects to flame arrestor.
Griff 04-11-2015 01:22 AM
1 Attachment(s)
My 2000 502mpi's are like I described. Starboard side is PVC and hose to underside of front upper intake. Port side plastic fitting in valve cover and then goes to flame arrestor.
