-   -   Blue 500s hourly maintenance ??? (https://www.offshoreonly.com/forums/general-q/325088-blue-500s-hourly-maintenance.html)
fordf350 04-13-2015 01:29 PM
1 Attachment(s)
I am literally days away from returning once again from a deployment and I would like to go from my 29 Fever to a 35 Ex or maybe a 38. There are three 35s that I will be going to look at. The1st boat has 200hrs on 500 EFIs. 2nd boat has 300hrs on 500 EFIs and the third has 360hrs on 500 Carbs. What are the maintenance concerns or issues with the hours on these engines? Can I get away with running the 200hr boat for a summer? Thanks[ATTACH=CONFIG]539849
getrdunn 04-13-2015 01:48 PM
From past experience 400 plus hours is the time for rebuilds. I am sure some would debate this however I boated with several friends for years and that seemed to be a good time line before desaster struck. That was running pretty consistently hard. On the flip side I know of some that would get up to 1k plus hours just doing routine maintenance and be fine however they didn't run near as hard as others.
imartin 04-13-2015 01:49 PM
First and foremost, thank you for your service!!! As a recent blue motor owner, I don't have all the knowledge needed, but have learned alot on this forum. If it was me, I would knock out the Carb engine without question. Again, just me, I'm sure I will get blasted, but believe the EFI is a more stable and steady offering. Of the two EFI's being considered, most will agree, it all depends on how those hours were spent. If you can get the run history report for both, look for where the hours were spent. I would prefer higher "easy" hours over lower "hard/WOT" hours. I hear 300 is the magic number for top end work on these Blues. Weak OEM springs being the culprit that can lead to other issues. So, that said, the 200 hrs boat, if not abused, likely would be first choice for a summer of fun. Well deserved and earned I will add!!! We Salute you!
getrdunn 04-13-2015 01:49 PM
Btw congrats on a safe return. Enjoy your time back on home turf.
getrdunn 04-13-2015 01:53 PM
Originally Posted by imartin (Post 4291610)
First and foremost, thank you for your service!!! As a recent blue motor owner, I don't have all the knowledge needed, but have learned alot on this forum. If it was me, I would knock out the Carb engine without question. Again, just me, I'm sure I will get blasted, but believe the EFI is a more stable and steady offering. OF the two EFI's being considered, most will agree, it all depends on how those hours were spent. If you can get the run history report for both, look for where the hours were spent. I would prefer higher "easy" hours over lower "hard/WOT" hours. I hear 300 is the magic number for top end work on these Blues. Weak OEM springs being the culprit that can lead to other issues. So, that said, the 200 hrs boat, if not abused, likely would be first choice for a summer of fun. Well deserved and earned I will add!!! We Salute you!
Thumbs up!
Wildman_grafix 04-13-2015 01:54 PM
Can't get anything but hours ran on the 500EFI's, the other data only became available with 525 EFI.
Just as a reference, I have 500EFI's did top ends around 250-280 hours.
We have ran them on the dyno, all looks good and my engine builder says run them to 500-600 hours. They are at 370-378 right now.
Once the boat is back togather I may start building long blocks and just have them ready to switch over to.
fordf350 04-13-2015 02:00 PM
The 360 hr boat is last on my list and the 200 hr boat is 220 miles closer to me than the 300hr and they are almost identical in looks and trailer. 200hr boat is listed $4000 less.
imartin 04-13-2015 02:40 PM
sounds like a no brainer to me.....Go get the 200hr boat and bask in the fun and sun....some real R&R.......
kennyo 04-13-2015 03:01 PM
I've heard and can verify 200 hrs is max on the valve springs. Mine were broke all to hell at 170 hours....
1989mach1 04-13-2015 03:05 PM
I did my top ends at 345 hours and missed it by a few. I had a lifter blow apart in the starboard motor and cost me an arm and a leg over what it should have been. I would say get the 200 hour one and after this summer do top ends spring's gaskets and clean up the valves if needed. Also have the drives completely gone throw to prevent failure. If you r paying to have it done it should run you around 5 to 7 k to do both top ends and about 2 or 3 k to have the drives completely gone throw. Doing all this sooner then later will save you money in the long run. With the broken parts I ended up with cost me a extra 10k . I also did new lifters on the port motor as well so both had all the same nuw parts except the cam witch only the one got replaced. Good luck to ya
1989mach1 04-13-2015 03:13 PM
I believe that 500efi's can do full hour run down as well but only on the motors that are 01 and newer if I remember correctly. But I could be wrong it has happened befor lol
1989mach1 04-13-2015 03:18 PM
Before u buy have a full survey done and also a compression test and a leak down test done on both motors that will tell you alot about the boat.
fordf350 04-13-2015 03:22 PM
I was going to look at them first and if they still had my interest. Than have a survey done.
1989mach1 04-13-2015 03:39 PM
For shure thats the way to go. Its well worth the money to have everything checked out be for u thow down the coin.
1989mach1 04-13-2015 03:41 PM
What years r the boats?
hardcore 04-13-2015 03:47 PM
Defineately agree, had triple 500 in my last boat,98 outerlimits, checked valve springs around 150 hours found 1 broken replaced them all, checked again at 300 hours again found one broken, replaced them all again. If you go with the 200 hour boat, change the valve springs, not hard to do and will be money well spent.
boatnt 04-13-2015 03:50 PM
why not buy a 35 with 502s or 496HOs? trouble free boating for a couple of miles less.
fordf350 04-13-2015 11:14 PM
Both EFI boats are 03s and the carbureted one is a 2000
fordf350 04-13-2015 11:18 PM
[QUOTE=boatnt;4291686]why not buy a 35 with 502s or 496HOs? trouble free boating for a couple of miles less.
I have not ruled out 496s or 502s. Black Mercurys are just fine and every boat I own has a Mercury on it or in it. The 454 EFIs in my 29 are and have been great. But I want any added performance the 500s provide and if the one in Canada that had 500s with 671 blowers on it was still available I would be going there first. He sold it the day I got my passport. :(
billpor930 04-13-2015 11:37 PM
The carburated 500's are the ones that had the early problems with valve springs. The 500 efi did not have these problems. This is not to say that you can ignore routine maintenance but they didn't break springs like the hp 500's did.
hardcore 04-13-2015 11:51 PM
Thanks for the info Billpor930, i did not know that the springs were changed with the EFI motors.
