-   -   Fast EZ-EFI 2.0 (https://www.offshoreonly.com/forums/general-q/325190-fast-ez-efi-2-0-a.html)
800XCR 04-16-2015 10:04 AM
Fast EZ-EFI 2.0
Anybody have any experience with this system in any environment? Thoughts on it?
Black Baja 04-16-2015 10:43 AM
I was seriously thinking about buying one until I researched it and read all the horror stories...
Quick2500 04-16-2015 05:14 PM
I have the first version and love it. There are a few little tricks, like adjusting the throttle blades properly to limit idle droop when shifting as the iac can be a touch lazy, but it has performed wonderfully.
Gimme Fuel 04-16-2015 06:57 PM
Look into the Holley HP EFI system. Works amazing for marine use.
800XCR 04-16-2015 08:28 PM
I have been looking at both, Holley is $1000 more $.
Rookie 04-16-2015 08:42 PM
2 Attachment(s)
I helped JimV install and tune 2 systems on a pair of 540's he built. As stated earlier there were a couple tricky things to address. Tuning was pretty straight forward, answer a few questions, choose your AFR, RPM and go. Just a couple things to consider. It is always tuning (need O2's) & NA only. Once it was setup it ran flawless all summer. I was also considering the Fast EZ 2.0, but I will eventually be going to blowers so the Holley HP will probably be my choice if pricing is reasonable.
HaxbySpeed 04-16-2015 10:01 PM
http://www.summitracing.com/int/parts/fst-3011454-10e
http://www.summitracing.com/int/part...-830/overview/
http://www.summitracing.com/int/parts/hly-522-488
Looks like they're about the same price on Summitt, but the Holley is more powerful, more durable, more expandable/upgradeable, coast guard approved, has better tech support, and is more versatile. I can beat both those prices, and give you a base tune to get you going, or help you tune it remotely.
hadleycat 04-17-2015 08:42 AM
I ordered my Holley through Haxby Speed. Very happy!
Cole2534 04-17-2015 09:59 AM
What's the difference between the HP, Dominator, and Terminator EFI's from Holley?
Rookie 04-17-2015 11:59 AM
The Dominator has more programmable I/O's and some transmission stuff.
"Both systems share the same firmware. Hardware
The following differentiate these two ECU’s:
- Wide Band Oxygen Sensor Inputs
o HP – One input
o Dominator – Two inputs
- The Dominator can control certain Drive by Wire throttle body applications, the HP does not.
- The Dominator can control certain Electronic Transmissions (GM 4L60/5E and 4L80/5E), the HP does not.
- Inputs and Outputs
o HP  2 high side (+12v) PWM or switched outputs
 2 low side (ground) PWM or switched outputs  4 Multi-inputs
o Dominator
 20 high side (+12v) PWM or switched outputs  16 how side (ground) PWM or switched outputs  6 speed inputs (magnetic or hall effect)  30 0-5v sensor inputs  13 Multi-inputs
- The Dominator has a “configuration input selection” pin that allows up to 4 calibrations to be selected with a key switch."
https://www.google.com/url?sa=t&sour...BV5gf1U4QN854Q
adk61 04-17-2015 12:33 PM
now there's an offer nobody can refuse!!!
launchpad475 04-17-2015 01:39 PM
I agree, Alex helped me with the Holley swap and set up. Once you dabble in the software a bit, it's all real user friendly. You can even shoot water out the side of a building with it.
https://www.youtube.com/watch?v=32baPITiock
HaxbySpeed 04-17-2015 01:46 PM
Lol. I don't always drink beer while running the dyno, but when I do, I prefer MGD.
launchpad475 04-17-2015 01:53 PM
that was a long day, you earned it. Plus, when the smaller pulley conversation comes up the beer always helps with bad decisions!
Cole2534 04-17-2015 02:27 PM
Side question for Haxby- why chop the throttle so hard after a pull? Just curious.
Black Baja 04-17-2015 03:58 PM
He was getting over anxious with the beer sitting next to the controls
