-   -   Marine grade silicone (https://www.offshoreonly.com/forums/general-q/325323-marine-grade-silicone.html)
Martini79 04-19-2015 11:03 PM
Who makes a high quality marine grade silicone I can use on the exterior of my boat that will not shrink and not yellow. looking for a bright white. thanks in advance
Crude Intentions 04-19-2015 11:18 PM
4200 if you wanna take it apart ever and 5200 if you don't.
brian41 04-20-2015 06:48 AM
Life Seal
US1 Fountain 04-20-2015 07:53 AM
3M marine.
Gotta watch using alot of the adhesive stuff. Most of those aren't UV resistant and don't like direct sunlight. Read the labels.
Bondo 04-21-2015 07:06 AM
Ayuh,.... Sillycones have No place on a boat,...... There are much better sealants to use, such as those mentioned above,....
Wildman_grafix 04-21-2015 07:27 AM
Originally Posted by brian41 (Post 4294225)
Life Seal
Why is it Brian always recommends this and no one else? I talked to a buddy of mine that used to build big custom Crusiers and he said they always used life seal products.
sutphen 30 04-21-2015 07:43 AM
bs they don't,double DD's doing a dirty dance on the bow is always a hit.:)
sorry had to be the first to say it.
apollard 04-21-2015 08:14 AM
I've used it before. Worked fine, but not much easier to remove the through hull than 4200 when i had to take it off again IME. It did seal as well as 4200.
brian41 04-21-2015 09:09 AM
I would put the Life Seal at a 3M 3200 if they made it.
minxguy 04-21-2015 09:59 AM
Brian, what Life Seal product are you talking about? Is it Life Seal silicone?
Ken
brian41 04-21-2015 10:53 AM
Boatlife life-seal........mildew resistant, fast curing, non-shrinking, Use above or below waterline. Its a mix of silicone and polyurethane.
BUP 04-21-2015 11:13 AM
3m 4200 never had any issues with installs - from rub rails to depth finders to pitot tubes to trim tabs and every darn screw or bolt that need it. Even fix some Formula boats that had their debonding issues for the shoe box fit the top cap to the hull.
Speedracer29 04-21-2015 12:39 PM
3M has a 4000UV hybrid. "Hybrid" being polyether. White, kicks fast, good strength, UV resistant. Like Frank's Red Hot for boats.
http://multimedia.3m.com/mws/media/4...6580-06586.pdf
http://multimedia.3m.com/mws/media/7...oduct-info.pdf
MrCIG 04-21-2015 08:31 PM
+ 1. Been working on boats for over 30 years have always used Boatlife when installing below and above water fittings and drives. Never had any issues
Mark
Drew555 04-21-2015 08:34 PM
3m 5200 only thing is it's forever
brian41 04-22-2015 06:50 AM
3 Attachment(s)
I have rigged this same set of boxes and drives on 3 different boats in the past 5 years. The first time I used 4200 and when we removed it from the first boat gelcoat and glass came with it. We used Life-seal for the second boat and it was much easier to remove with zero damage.
Cole2534 04-22-2015 07:12 AM
Better question - are either of these products, Lifeseal or 4200, available anywhere but a marine place? Like if I needed some in a pinch.
Bondo 04-22-2015 02:16 PM
Ayuh,.... Yer Right,..... My bad,....
Wildman_grafix 04-22-2015 02:53 PM
Glad to here about the life seal as that is what I have been using, screws included.
Here you can get the 3M product at Home Depot! But I have a couple of buddies with Lewis marine accounts so I just get the stuff there.
shunter2005 04-22-2015 05:57 PM
If you need the big 10 oz tube, haven't seen them anywhere except a marine place. However, if you need some in a pinch, you can get 3 oz. tubes of white 4200 and white 3M marine silicone at Academy stores (if you have them in OK.). One big tube is more than 3x the amount of the small tube and will cost less than two small tubes, even at West Marine.
At Academy, the 3 oz tube 4200 is $11.99 and 3oz tube Silicone is $12.99. Go figure....
I used LifeSeal mahogany color caulk on my antique wood boat and it dried out and started flaking off, even under varnish. I have used other LifeSeal products for other projects and they have done fine. May just be that particular product.
Cole2534 04-22-2015 06:17 PM
Hadn't even considered academy. Yes we have them! Between the oil wells and teepees!
shunter2005 04-22-2015 06:50 PM
Shouldn't that be casinos now???
Brandonb_05 04-22-2015 08:30 PM
Lowes has the smaller tubes of the 3M
Cole2534 04-22-2015 09:22 PM
And windmills. I hate them both with extreme prejudice
shunter2005 04-22-2015 09:51 PM
Well, that's just my luck. I checked at Home Depot and they didn't have anything close, so I just figured that Lowe's wouldn't either.
TomFTM 04-23-2015 07:15 PM
Life Seal
X2 that's all I use..
Brandonb_05 04-24-2015 09:04 AM
Check lowes over by the paint section near all the caulking materials, that's where they have it in my local lowes. Never stop improving :evilb:
