-   -   Volt gauge reading (https://www.offshoreonly.com/forums/general-q/32552-volt-gauge-reading.html)
mpally 09-08-2002 01:38 PM
Volt gauge reading
We have a 88 stock 454. The normal reading on the volt gauge is right at 12. Sometimes it drops a bit below, and sometimes it is a tad ablout 12. Do we have a problem? We had our mechanic down at the boat the other day and he said everything seems to be charging fine. Any thoughts?
formula31 09-08-2002 03:08 PM
You need to check the voltage right at the batteries with a good voltmeter (VOM) (DVM) etc. It should read between 13 and 14 volts. Then, witht he engine running at a high idle, turn on your blower, bilge pump running lights etc. and check the voltage again to make sure it stays up there.
Gearhead99 09-08-2002 03:42 PM
You need to do what Formula31 said and check it at the battery. If you go just by the gauge, reading 12 volts, you have a problem. But, if you have 13+ at the battery running then the gauge is wrong and reading low.
Could be the gauge or could be the wiring going to the gauge.
mopower 09-08-2002 08:00 PM
I had 12 on my guages and 13.5 on the back of ignitions switches:( . Found and oxidized connection behind the instrument panel Cleaned and tightened and now matches the batteries in the back:D
