Morel 4603 lifter noise >
Old 03-23-2016 | 11:44 AM
  #131
Originally Posted by Budman II
BB, you were running 60 wt oil with 100+ lbs of oil pressure? That's not far from gear lube! That had to have put an incredible load on the distributor drive gear. Were you running one of the bronze ones for a billet cam, or one ones?
Billet cam with a cast gear.
Black Baja is offline
Old 03-26-2016 | 09:07 AM
  #132
Looks like we might try Howard's 91161. anyone have any experience with Howard's? Will they hold up to 160 seat pressure?
1MOSES1 is offline
Old 03-26-2016 | 09:45 AM
  #133
that lifter will work w/ 160lbs on the set and 500lbs over the nose.
sutphen 30 is offline
Old 03-26-2016 | 02:09 PM
  #134
that lifter is advertized as a street lifter,just saying.it might not be the best choice.
mike tkach is offline
Old 03-26-2016 | 04:11 PM
  #135
What do you recommend? Keep in mind this is a stock 500 efi nothing crazy. I've been doing a lot of research and can't come up with an alternative other than morel...
1MOSES1 is offline
