-   -   BBC Engine missing side caps? (https://www.offshoreonly.com/forums/general-q/326028-bbc-engine-missing-side-caps.html)
Cole2534 05-11-2015 08:06 AM
Originally Posted by Baja Rooster (Post 4302846)
Has anyone popped a freeze plug and not have a cracked block? Doesn't sound like the system works very well. ;)
Freeze plug is a misnomer.
SB 05-11-2015 08:23 AM
Correct. It's a core plug.
People named it freeze plug / frost plug because they tend to pop out when block freezes.
It's kind of like a Oven Roaster Chicken. When it 'pops' it is usually done.
Cole2534 05-11-2015 08:26 AM
And they damn sure don't prevent any damage to the block. I get the feeling that some people think they're there as a relief device.
28Eliminator 05-11-2015 08:33 AM
I have seen several people get lucky with replacing the freeze plug. If they actually winterize the boat but some water stays in the side of the block with to much sand (mostly because they power onto the beach with motor running), then it will push out the freeze plug. I am always very skeptical, but even last spring one of guys down the street stopped by and asked why he found this strange plug in the bottom of his bilge. He went to the auto parts store and bought a rubber freeze plug and boated all season with it. Where we boat we have a lot of sandy beaches, so if the isn't your case and winterization wasn't performed, your block is most likely cracked.
adk61 05-11-2015 09:00 AM
that's because its a core plug... not a commonly mistaken "freeze plug" they put these in so they can get the sand out after the block has been cast!!!
mike tkach 05-11-2015 09:38 AM
i wonder how long it will take for a certian expert to say it popped out because the water was not cooling the metal in the block,lol.
F-2 Speedy 05-11-2015 10:04 AM
Remember the guy in TX, said they popped out because the sun was to hot...................... ahhhh ok
F-2 Speedy 05-11-2015 10:06 AM
yes, they keep the freeze in
adk61 05-11-2015 10:13 AM
now now... lets play nice :hitfan:
BUP 05-11-2015 12:10 PM
Post 25 is correct and FWIW Mercruiser calls and lists them as expansion plugs. Just saying, everyone calls them freeze plugs (on the side of block) especially for the marine side of things..
